New re-install that worked fine on 0.63.0.
Have the following blow-up in my log file and also when I do --script check_config:
`2018-02-13 22:17:15 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File “/usr/lib/python3.5/asyncio/tasks.py”, line 241, in _step
result = coro.throw(exc)
File “/srv/homeassistant/lib/python3.5/site-packages/homeassistant/setup.py”, line 57, in async_setup_component
return (yield from task)
File “/usr/lib/python3.5/asyncio/futures.py”, line 380, in iter
yield self # This tells Task to wait for completion.
File “/usr/lib/python3.5/asyncio/tasks.py”, line 304, in _wakeup
future.result()
File “/usr/lib/python3.5/asyncio/futures.py”, line 293, in result
raise self._exception
File “/usr/lib/python3.5/asyncio/tasks.py”, line 239, in _step
result = coro.send(None)
File “/srv/homeassistant/lib/python3.5/site-packages/homeassistant/setup.py”, line 104, in _async_setup_component
component = loader.get_component(domain)
File “/usr/lib/python3.5/unittest/mock.py”, line 919, in call
return _mock_self._mock_call(*args, **kwargs)
File “/usr/lib/python3.5/unittest/mock.py”, line 985, in _mock_call
ret_val = effect(*args, **kwargs)
File “/srv/homeassistant/lib/python3.5/site-packages/homeassistant/scripts/check_config.py”, line 179, in mock_get
module = MOCKS[‘get’]1
File “/srv/homeassistant/lib/python3.5/site-packages/homeassistant/loader.py”, line 142, in get_component
module = importlib.import_module(path)
File “/usr/lib/python3.5/importlib/init.py”, line 126, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File “”, line 986, in _gcd_import
File “”, line 969, in _find_and_load
File “”, line 958, in _find_and_load_unlocked
File “”, line 673, in _load_unlocked
File “”, line 673, in exec_module
File “”, line 222, in _call_with_frames_removed
File “/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/history.py”, line 19, in
from homeassistant.components import recorder, script
File “/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/script.py”, line 21, in
from homeassistant.helpers.entity_component import EntityComponent
File “/srv/homeassistant/lib/python3.5/site-packages/homeassistant/helpers/entity_component.py”, line 15, in
from .entity_platform import EntityPlatform
File “”, line 669, in exec_module
File “”, line 773, in get_code
File “”, line 484, in _compile_bytecode
EOFError: marshal data too short
future.result()
File “/srv/homeassistant/lib/python3.5/site-packages/homeassistant/setup.py”, line 111, in _async_setup_component
components = loader.load_order_component(domain)
File “/srv/homeassistant/lib/python3.5/site-packages/homeassistant/loader.py”, line 241, in load_order_component
return _load_order_component(comp_name, OrderedSet(), set())
File “/srv/homeassistant/lib/python3.5/site-packages/homeassistant/loader.py”, line 269, in _load_order_component
dep_load_order = _load_order_component(dependency, load_order, loading)
File “/srv/homeassistant/lib/python3.5/site-packages/homeassistant/loader.py”, line 250, in _load_order_component
component = get_component(comp_name)
File “/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/api.py”, line 26, in
from homeassistant.helpers.state import AsyncTrackStates
File “/srv/homeassistant/lib/python3.5/site-packages/homeassistant/helpers/state.py”, line 9, in
from homeassistant.components.media_player import (
File “/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/media_player/init.py”, line 32, in
2018-02-13 22:17:16 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
future.result()
File “/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/scene/init.py”, line 17, in
future.result()
File “/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/tts/init.py”, line 21, in
future.result()
File “/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/input_select.py”, line 16, in
future.result()
File “/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/group/init.py”, line 21, in
future.result()
File “/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/sensor/init.py”, line 11, in
future.result()
File “/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/cover/init.py”, line 15, in
future.result()
File “/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/emulated_hue/init.py”, line 22, in
from .hue_api import (
File “/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/emulated_hue/hue_api.py”, line 13, in
from homeassistant.components.light import (
File “/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/light/init.py”, line 15, in
from homeassistant.components import group
future.result()
and some more (but can’t post more)
