I got really annoyed with configuring the same parameters on multiple nodes over and over again and because I couldn’t really find anything to automate this, I put a couple of scripts together to do that. Unfortunately, I am not a programer and it’s probably pretty ugly, but I was hoping that somebody might have a better solution
script:
slave_configure_aeotec_switch:
alias: ZW Aeotec Switch
sequence:
- service: script.slave_configure_aeotec_switch_parameter_scheduled
entity_id: zwave.example_node_1
entity_id: zwave.example_node_2
entity_id: zwave.psw_foyer_spot
entity_id: zwave.psw_living_column
- service: script.slave_configure_aeotec_switch_parameter_threshold
entity_id: zwave.psw_master_ac
entity_id: zwave.psw_mini_ac_bathroom
entity_id: zwave.psw_office_ac
entity_id: zwave.psw_office_desk
entity_id: zwave.psw_tech_ac
slave_configure_aeotec_switch_parameter_scheduled:
alias: ZW Aeotec Switch Parameter to scheduled
mode: queued
max: 10
fields:
entity_id:
description: 'Entity ID of node'
example: 'zwave.sensor_bathroom'
sequence:
# Notification Type: Hail
- service: zwave.set_config_parameter
data_template:
node_id: "{{ state_attr(entity_id,'node_id') }}"
parameter: 80
value: "Hail"
- delay: 00:00:15
## Report on Thresholds
# - service: zwave.set_config_parameter
# data_template:
# node_id: "{{ state_attr(entity_id,'node_id') }}"
# parameter: 90
# value: "False"
# - delay: 00:00:15
# Group 1 Report Type
data_template:
parameter: 101
value: 12
- delay: 00:00:15
# Group 2 Report Type
data_template:
parameter: 102
value: 0
- delay: 00:00:15
## Group 3 Report Type
data_template:
parameter: 103
value: 0
- delay: 00:00:15
## Group 1 Report Interval
data_template:
parameter: 111
value: 900
- delay: 00:00:15
## Group 2 Report Interval
data_template:
parameter: 112
value: 0
- delay: 00:00:15
## Group 3 Report Interval
data_template:
parameter: 113
value: 0
- delay: 00:00:15
slave_configure_aeotec_switch_parameter_threshold:
alias: ZW Aeotec Switch Parameter to threshold
mode: queued
max: 10
fields:
entity_id:
description: 'Entity ID of sensor'
sequence:
data_template:
parameter: 80
value: "Hail"
- delay: 00:00:15
# data_template:
# parameter: 90
# value: "True"
# - delay: 00:00:15
# Threshold Watts
data_template:
parameter: 91
value: 25
- delay: 00:00:15
# Threshold Percent
# data_template:
# parameter: 92
# value: 10
# - delay: 00:00:15
data_template:
parameter: 101
value: 12
- delay: 00:00:15
data_template:
parameter: 102
value: 0
- delay: 00:00:15
data_template:
parameter: 103
value: 0
- delay: 00:00:15
data_template:
parameter: 111
value: 900
- delay: 00:00:15
data_template:
parameter: 112
value: 0
- delay: 00:00:15
data_template:
parameter: 113
value: 0
- delay: 00:00:15
