I have a rather complex config, the user needs to supply their own mappings and I allow them to override some values to handle devices I can’t test.
So it would look something like this:
"options": {
"devices": [
"id": 1234,
"type": "switch"
"id": 5678,
"type": "binary_sensor"
There seems to be no way to create a schema validation to handle this.
If I do as follows then the entire config fails to even load.
"schema": {
"devices": [
"id": "int",
"type": "str"
If I set "schema": false
then there is no way to configure from the UI.
Update
Since there seems to be no solution and the UI fails when schema = false, I moved the extra configs into separate json files that will be reader/written from in the “config” map.
