Config splitting by packages: how do you exclude whole folders?
Assume that splitting is made by using packages:
homeassistant:
  packages: !include_dir_named conf
and you have a tree-like structure like this one:
The idea is to keep config in folders like “Volvo XC9999”, “Garden”, “Device XYZ”.
And if I need to disable some package, I have to rename yaml-file(s) - change an extension from “.yaml" to smth like ".dis”.
And if I need to disable a whole FOLDER - this renaming should be done for each yaml-file inside this folder.
Is there any SIMPLER way to exclude the whole folder from this “packaging” process?
(and I do not want to move this folder out of the “conf” folder)
Registered a FR for this: Using packages for config splitting: ignoring folders
I’m not aware of such functionality.
But what you can do is this:
Make a wrapper script for your HA restart command. In that script check for your chosen naming convention to indicate a disabled folder. Rename all the files in that folder. And vice versa.
Or you could make a script using a file watcher which you run as a daemon. This can then do the same renaming as above.
Thanks a lot for sharing experience.
I was thinking about mass-renaming files…
Even created a *.bat file (or how it is called in *nix) to rename them.
But I found this not convenient.
What I do currently:
  1. If one file (several files) are excluded - rename them to “*.dis” (even if whole folder is excluded) (+keep in mind that some file could be already excluded).
  2. If a folder with subfolders is excluded - I have to move the folder outside into some dedicated folder (and have to keep in mind where this folder was located; this is not critical, it will work anyway wherever you place it back; just to keep an order).
A real life use-case: due to some work in my garden I have to temporarily disable all functionalities related to some building (electricity, climate control, security etc).
In a large setup excluding / including packages by moving them is not a good idea…
Everything must be in order ).
