Hey,
I have an ESP using the adc platform that no longer compiles since 2024.12. It compiled and is working right now with version 2024.11.3. I read that there were breaking changes with 2024.12, but I don’t see how they apply. I’m pretty dumb with this esp stuff so I could use some help please.
Config:
esphome:
platform: ESP32
board: nodemcu-32s
- platform: adc
pin: GPIO39
update_interval: 0.1s
unit_of_measurement: "in"
accuracy_decimals: 2
attenuation: auto
filters:
- lambda: return ((x-0.1)/3.0*300.0-100.0)-1.8;
- exponential_moving_average:
alpha: 0.01
send_every: 100
Error:
/opt/esphome/.platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: .pioenvs/radon-manometer/src/esphome/components/adc/adc_sensor_common.cpp.o: in function `esphome::adc::ADCSensor::get_setup_priority() const':
/opt/esphome/.esphome/build/radon-manometer/src/esphome/components/adc/adc_sensor_common.cpp:21: multiple definition of `esphome::adc::ADCSensor::get_setup_priority() const'; .pioenvs/radon-manometer/src/esphome/components/adc/adc_sensor.cpp.o:/opt/esphome/.esphome/build/radon-manometer/src/esphome/components/adc/adc_sensor.cpp:145: first defined here
/opt/esphome/.esphome/build/radon-manometer/src/esphome/components/adc/adc_sensor_common.cpp:21: multiple definition of `non-virtual thunk to esphome::adc::ADCSensor::get_setup_priority() const'; .pioenvs/radon-manometer/src/esphome/components/adc/adc_sensor.cpp.o:/opt/esphome/.esphome/build/radon-manometer/src/esphome/components/adc/adc_sensor.cpp:145: first defined here
/opt/esphome/.platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: .pioenvs/radon-manometer/src/esphome/components/adc/adc_sensor_common.cpp.o: in function `esphome::adc::ADCSensor::update()':
/opt/esphome/.esphome/build/radon-manometer/src/esphome/components/adc/adc_sensor_common.cpp:9: multiple definition of `esphome::adc::ADCSensor::update()'; .pioenvs/radon-manometer/src/esphome/components/adc/adc_sensor.cpp.o:/opt/esphome/.esphome/build/radon-manometer/src/esphome/components/adc/adc_sensor.cpp:146: first defined here
/opt/esphome/.platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: .pioenvs/radon-manometer/src/esphome/components/adc/adc_sensor_common.cpp.o: in function `non-virtual thunk to esphome::adc::ADCSensor::update()':
adc_sensor_common.cpp:(.text._ZThn80_N7esphome3adc9ADCSensor6updateEv+0x0): multiple definition of `non-virtual thunk to esphome::adc::ADCSensor::update()'; .pioenvs/radon-manometer/src/esphome/components/adc/adc_sensor.cpp.o:adc_sensor.cpp:(.text._ZThn80_N7esphome3adc9ADCSensor6updateEv+0x0): first defined here
/opt/esphome/.platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: .pioenvs/radon-manometer/src/esphome/components/adc/adc_sensor_common.cpp.o: in function `esphome::adc::ADCSensor::set_sample_count(unsigned char)':
/opt/esphome/.esphome/build/radon-manometer/src/esphome/components/adc/adc_sensor_common.cpp:15: multiple definition of `esphome::adc::ADCSensor::set_sample_count(unsigned char)'; .pioenvs/radon-manometer/src/esphome/components/adc/adc_sensor.cpp.o:/opt/esphome/.esphome/build/radon-manometer/src/esphome/components/adc/adc_sensor.cpp:152: first defined here
/opt/esphome/.platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: .pioenvs/radon-manometer/src/esphome/components/adc/adc_sensor_esp32.cpp.o: in function `esphome::adc::ADCSensor::setup()':
/opt/esphome/.esphome/build/radon-manometer/src/esphome/components/adc/adc_sensor_esp32.cpp:24: multiple definition of `esphome::adc::ADCSensor::setup()'; .pioenvs/radon-manometer/src/esphome/components/adc/adc_sensor.cpp.o:/opt/esphome/.esphome/build/radon-manometer/src/esphome/components/adc/adc_sensor.cpp:46: first defined here
/opt/esphome/.platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: .pioenvs/radon-manometer/src/esphome/components/adc/adc_sensor_esp32.cpp.o: in function `non-virtual thunk to esphome::adc::ADCSensor::setup()':
adc_sensor_esp32.cpp:(.text._ZThn80_N7esphome3adc9ADCSensor5setupEv+0x0): multiple definition of `non-virtual thunk to esphome::adc::ADCSensor::setup()'; .pioenvs/radon-manometer/src/esphome/components/adc/adc_sensor.cpp.o:adc_sensor.cpp:(.text._ZThn80_N7esphome3adc9ADCSensor5setupEv+0x0): first defined here
/opt/esphome/.platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: .pioenvs/radon-manometer/src/esphome/components/adc/adc_sensor_esp32.cpp.o: in function `esphome::adc::ADCSensor::dump_config()':
/opt/esphome/.esphome/build/radon-manometer/src/esphome/components/adc/adc_sensor_esp32.cpp:57: multiple definition of `esphome::adc::ADCSensor::dump_config()'; .pioenvs/radon-manometer/src/esphome/components/adc/adc_sensor.cpp.o:/opt/esphome/.esphome/build/radon-manometer/src/esphome/components/adc/adc_sensor.cpp:96: first defined here
/opt/esphome/.platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: .pioenvs/radon-manometer/src/esphome/components/adc/adc_sensor_esp32.cpp.o: in function `non-virtual thunk to esphome::adc::ADCSensor::dump_config()':
adc_sensor_esp32.cpp:(.text._ZThn80_N7esphome3adc9ADCSensor11dump_configEv+0x0): multiple definition of `non-virtual thunk to esphome::adc::ADCSensor::dump_config()'; .pioenvs/radon-manometer/src/esphome/components/adc/adc_sensor.cpp.o:adc_sensor.cpp:(.text._ZThn80_N7esphome3adc9ADCSensor11dump_configEv+0x0): first defined here
/opt/esphome/.platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: .pioenvs/radon-manometer/src/esphome/components/adc/adc_sensor_esp32.cpp.o: in function `esphome::adc::ADCSensor::sample()':
/opt/esphome/.esphome/build/radon-manometer/src/esphome/components/adc/adc_sensor_esp32.cpp:84: multiple definition of `esphome::adc::ADCSensor::sample()'; .pioenvs/radon-manometer/src/esphome/components/adc/adc_sensor.cpp.o:/opt/esphome/.esphome/build/radon-manometer/src/esphome/components/adc/adc_sensor.cpp:177: first defined here
/opt/esphome/.platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: .pioenvs/radon-manometer/src/esphome/components/adc/adc_sensor_esp32.cpp.o: in function `non-virtual thunk to esphome::adc::ADCSensor::sample()':
adc_sensor_esp32.cpp:(.text._ZThn100_N7esphome3adc9ADCSensor6sampleEv+0x0): multiple definition of `non-virtual thunk to esphome::adc::ADCSensor::sample()'; .pioenvs/radon-manometer/src/esphome/components/adc/adc_sensor.cpp.o:adc_sensor.cpp:(.text._ZThn100_N7esphome3adc9ADCSensor6sampleEv+0x0): first defined here
collect2: error: ld returned 1 exit status
*** [.pioenvs/radon-manometer/firmware.elf] Error 1
