Config Zigabee2mqtt
Good morning, why don’t I collect the information of a temperature sensor when I add a card in the HA summary panel? I don’t see the data in mosquito either, but when I enter the zigbee2mqtt panel I do see the temperature and humidity data. Thank you very much!!
Do you have other zigbee2mqtt devices that report to Home Assistant correctly?
If not, then this:
would point to a communication error between zigbee2mqtt and your mqtt broker.
Check your zigbee2mqtt broker configuration.
