I’m trying to create a ConfigFlow for an existing integration but am stuck on just the form displaying text. The text entries are displayed for the 3 inputs but no descriptions
I enabled config_flow: true
in the manifest.json
Created a strings.json
and ran the command to populate the .translations/en.json
file
const.py
"""Constants for Rainforest Eagle"""
DOMAIN = "rainforest_eagle"
CONF_CLOUD_ID = "cloudid"
CONF_INSTALL_CODE = "installcode"
config_flow.py
from homeassistant import config_entries
from homeassistant.const import CONF_HOST
import voluptuous as vol
from .const import (
DOMAIN,
CONF_CLOUD_ID,
CONF_INSTALL_CODE,
DATA_SCHEMA = {
vol.Required(CONF_HOST): str,
vol.Required(CONF_CLOUD_ID): str,
vol.Required(CONF_INSTALL_CODE): str,
class EagleConfigFlow(config_entries.ConfigFlow, domain=DOMAIN):
"""Config flow for Rainforest Eagle."""
VERSION = 1
async def async_step_user(self, user_input=None):
if not user_input:
return self.async_show_form(
step_id="user",
data_schema=DATA_SCHEMA,
errors={}, description_placeholders={},
strings.json
"config": {
"step": {
"user": {
"data": {
"cloudid": "Cloud ID",
"host": "Host",
"installcode": "Install Code"
When I run HA and setup the integration the form is blank. I’m not expecting much right now except for descriptions to appear but I don’t see them. Am I missing something? Thank you!
