Configurable Daily Weather Report
A clean, optimized Home Assistant blueprint designed to generate detailed daily weather notifications with custom region headings, dynamic unit conversion, timestamps, and quick links controlled via flexible triggers (Schedule, NFC, or Helper Switch).
:warning: Prerequisites:
  • Weather Entity: You must have an active weather integration set up in Home Assistant (weather.*, such as Met.no, AccuWeather, Environment Canada, etc.) to pull current conditions and daily forecasts.
  • Input Boolean Helper (Optional): If you plan to use a manual trigger switch, create your helper entity first in Home Assistant (Settings > Devices & Services > Helpers).
Features
  • Multi-Trigger Architecture: Trigger your weather report automatically via a daily schedule, by scanning an NFC tag, or instantly using an input boolean helper switch.
  • Auto-Resetting Helper Switch: Turning on the input boolean helper triggers the report and instantly resets the switch back to off (acting like a momentary push button).
  • Custom Region & Location Headings: Override entity names with a specific region name (e.g., “Courtenay, BC”) to format clean, custom headers.
  • Smart Temperature Unit Detection: Choose between Celsius (°C) and Fahrenheit (°F) with built-in native unit detection to prevent double-conversion on US Imperial system setups.
  • Universal Timestamps: Includes a discreet, globally understood timestamp (YYYY-MM-DD HH:MM) at the footer of every report.
  • Quick Links Integration: Easily attach links to your internal Home Assistant dashboard or external weather sources/search queries.
  • Mobile-Optimized UI Layout: Formatted using lightweight HTML and Markdown (<br>, bolding, dividers) for crisp readability on smartphones.
  • Operation Summary:
    Event Action Taken
    Schedule, NFC, or Helper Triggered Pulls modern forecast data, formats conditions/temperatures, and generates a robust persistent notification.
    Helper Switch Activated Automatically resets the input boolean back off immediately so it’s ready for the next manual trigger.
    Data Unavailable Gracefully handles missing weather attributes or forecast keys using safe fallbacks (N/A) without breaking the automation.
Blueprint Inputs
Input Description Required? Default
Weather Entity The weather entity to pull forecasts from (weather.*). Yes N/A
Custom Location / Region Name Override the entity name with a specific region (e.g., “Courtenay, BC”). Leave blank to use entity name. No ""
Temperature Unit Choose whether to display temperatures in Celsius (°C) or Fahrenheit (°F). Native °F source values are safely preserved without double conversion. Yes °C
Daily Schedule Time Time of day to run the report automatically. Yes 07:00:00
NFC Tag ID Scanning this tag ID will trigger the report. No ""
Input Boolean Helper Toggle switch entity (input_boolean.*) to manually trigger the report. Automatically turns off upon execution. No []
Internal Dashboard Path Path to your HA dashboard (e.g., /dashboard-sensors/temperatures). Leave blank to omit. No ""
External Weather Link URL to an external weather service or search query. No Environment Canada coords link
:light_bulb: Important Notes & Pro-Tips
  • Custom Region Names vs. Weather Data: The Custom Region Name input is strictly a visual text label override for your notification header. It does not change the underlying location of the weather data. If you want to receive weather reports for multiple different cities or locations, you must set up separate weather entities for each location in Home Assistant first, and then create a separate automation instance for each entity.
  • Momentary Trigger Switch Behavior: When triggered via the input_boolean helper, the blueprint resets the helper back to off at the start of execution. This prevents switches from staying toggled on in your UI and ensures it is always ready to be clicked again on demand.
  • Modern Weather Forecast Handling: This blueprint utilizes Home Assistant’s modern weather.get_forecasts service, ensuring full compatibility across standard weather integrations (Met.no, AccuWeather, Environment Canada, etc.).
  • Smart Unit Conversion: The blueprint checks the entity’s native temperature_unit attribute before applying math. If your Home Assistant system natively operates in °F, selecting °F will safely display raw values rather than converting them twice.
  • Smart Coordinate Lookups: The default external URL link uses coordinate lookups. You can easily find precise latitude and longitude values using tools like GPS Coordinates Finder.
  • Airtight Error Handling: The template code utilizes Python safe .get() methods and fallback defaults (N/A), meaning temporary weather integration hiccups won’t throw automation errors.
Installation
Method 1: Click to Import (Easiest)
Click the badge below to import this blueprint directly into your Home Assistant instance:
Method 2: Manual Installation
  1. Download or clone the raw YAML file from this repository: weather_report_notification.yaml
  2. In your Home Assistant configuration directory, navigate to your blueprints folder (e.g., config/blueprints/automation/ufans123/).
  3. Paste the code into a file named weather_report_notification.yaml.
  4. Reload your automations or restart Home Assistant.
Method 3: Manual Installation using the Blueprints Dashboard (Easier)
  1. Copy the following URL:
https://github.com/ufans123/home-assistant-blueprints/blob/main/weather_report_notification.yaml
  1. Navigate to your Home Assistant Blueprints Dashboard UI (Settings > Automations & Scenes > Blueprints).
  2. In the bottom right corner, click on the ‘Import blueprint’ button.
  3. Paste in the URL and follow the prompts.
Use Cases
Automated Morning Briefing Push
Schedule a daily notification (e.g., at 07:00 AM) to receive a clean, formatted weather summary for your region (such as “Courtenay, BC”) complete with current conditions, daily high/low temperatures, and severe weather alert callouts right as you wake up.
On-Demand NFC & Dashboard Triggering
Scan an NFC sticker on your nightstand or click a momentary input_boolean helper switch on your Home Assistant dashboard (input_boolean.weather_report) to generate an instant, updated weather report whenever you need it.
One-Tap Quick Link Navigation
Access deeper metrics quickly via embedded notification links—opening your local Home Assistant climate dashboard or jumping straight to external Environment Canada regional forecasts via coordinate lookups.
Changelog
Version Date Summary of Changes
v1.1 2026-11-08 Added severe weather alert handling for exceptional condition state in both current conditions and daily forecast, with dynamic card titles and callout warnings.
v1.0 2026-10-18 Initial release
