Here is how you format the code correctly:
you need to remove the line “cfg_alarm: !include /config/alarm_panel/cfg_alarm.yaml” from the "homeassistant: " (at line 16).
Then you need to put “alarm: !include cfg_alarm.yaml” in somewhere around line 70
Then make sure your “cfg_alarm.yaml” file is in the base config directory. This is the same location as your “automations.yaml” and “scripts.yaml” is located. I’m assuming those actually exist in your config directory since you already have them in your configuration.yaml file as !includes.
your basic configuration.yaml file should look something like this. See the last line for your include statement:
homeassistant:
# Name of the location where Home Assistant is running
# Location required to calculate the time the sun rises and sets
latitude: 43.013969
longitude: -77.404350
# Impacts weather/sunrise data (altitude above sea level in meters)
elevation: 719
# metric for Metric, imperial for Imperial
unit_system: imperial
# Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
time_zone: America/New_york
customize: !include customization.yaml
# Show links to resources in log and frontend
introduction:
# Enables the frontend
frontend:
# Enables configuration UI
config:
# Checks for available updates
# Note: This component will send some information about your system to
# the developers to assist with development of Home Assistant.
# For more information, please see:
# https://home-assistant.io/blog/2016/10/25/explaining-the-updater/
updater:
# Optional, allows Home Assistant developers to focus on popular components.
# include_used_components: true
# Discover some devices automatically
discovery:
# Allows you to issue voice commands from the frontend in enabled browsers
conversation:
recorder:
# Enables support for tracking state changes over time.
history:
# View all events in a logbook
logbook:
# Disable WARNINGS in log for Cameras. Refer here: https://home-assistant.io/components/logger/
logger:
map:
# Track the sun (original component)
sun:
- platform: yr
# Text to speech
tts:
platform: google
group: !include groups.yaml
script: !include scripts.yaml
alarm: cfg_alarm.yaml
I am also assuming that “alarm:” is a proper home assistant component. If the component doesn’t exist you will still get errors that will say “component not found”.
