I am new with Home Assistant and struggling with the formating. I am trying to split my configuration.yaml file up so I can understand it better, I have the main configuration.yaml file and trying to add a link to add another file call alarm.yaml. Here is what I have in the configuration file.:
need to post the whole thing including the contents of alarm.yaml. Only thing I see off the bat is that customize should be under the homeassistant: section not at the root level.
Also, follow the directions in blue at the top of the page. They will show you how to properly format yaml when posting it.
in principle your approach is correct but you have to watch a few things causing trouble
ensure there is no other object called ‘Alarm’ … this can cause naming conflict in some cases. I have named all my yaml files like … cfg_Alarm.yaml , cfg_lights.yaml
ensure the formatting in your Alarm.yaml is correct as this can throw errors as you have shown … if not sure you can Comment section by section and use the “Check Config” option in HA
and as @petro mentioned… read the guidelines on how to post content… reason for this is that YAML is very sensitive with formattting especially with the amount of “leading spaces” in your config files. the posting guidelines will ensure that the original format will be maintained and the community here can give you proper feedback
Thanks had a problem and saved the configuration.yaml file with the error. Had to reinstall the complete program.
Question one: Does a backup give you the ability to reload Home assistant?
Now the real problem, Receive the check configuration error: Configuration invalid CHECK CONFIG extra keys not allowed @ data[‘cfg_alarm’]
My understanding is that the OP is sub-dividing the configuration.yaml file and has chosen to define all of the security-related entities in the cfg_alarm.yaml file (located in the Alarm_Panel sub-directory).
That maybe the case, but he’s linked the file under a sub-key called cfg_alarm, under homeassistant: which doesn’t exist, so we need to know what he’s trying to achieve by using that key.
1, How do you post the yaml file, snap shot are not good?
2, All I am trying to do it just split the yaml file up so it is more manageable.
3. Even if I combine the two files I still get the error.
