Configuration and use of AirZone integration
Hello.
Currently the AirZone integration allows, in the interface, to select in a child zone any mode (heat, cool, fan only). However, AirZone, the devices, only allow this mode setting on the master (parent) zone.
I think it would be interesting to bring this behaviour to the AirZone integration so that in the parent zone you could change the mode, temperature and timer and in the daughters you could only turn on, off, temperature and timer.
Similarly, the daughter zones would only have 2 modes (off and the one considered) when switching to HomeKit integration. This way you wouldnā€™t have to remember which one you have set on the parent when you go to do just one of the children.
Best regards.
Hola.
Actualmente la integraciĆ³n de AirZone permite, en la interfaz, seleccionar en una zona hija cualquier modo (calor, frio, sĆ³lo ventilador). Sin embargo, AirZone, los aparatos, sĆ³lo dejan realizar esta configuraciĆ³n de modo en el dispositivo o zona maestra (padre).
Creo que serĆ­a interesante llevar este comportamiento a la integraciĆ³n de AirZone de manera que en el dispositivo de la zona padre se pudiera cambiar el modo, la temperatura y el temporizador y en las hijas sĆ³lo se pudiera encender, apagar, temperatura y temporizador.
De igual modo que las zonas hijas sĆ³lo dispongan de 2 modos (apagado y el que se considere) cuando se pasa a la integraciĆ³n de HomeKit. De esta manera no habrĆ­a que acordar de cuĆ”l tienes puesto en el padre cuando vas a hacer sĆ³lo uno de los hijos.
Un saludo.
Hi @ralvarez83,
Unfortunately we need to comply with Home Assistant architecture and this isnā€™t allowed in the current Home Assistant architecture, since thereā€™s no ā€œONā€ mode and the ā€œAUTOā€ mode doesnā€™t cover that scope.
Thereā€™s a discussion open since 2021 and so far it hasnā€™t been resolved:
Iā€™ve also opened a parallel discussion for abstracting the ON/OFF part from the HVAC mode:
Please, feel free to participate or upvote those discussions so that we can finally get this sorted out.
Is there a way to also select ā€œSTOPā€ in the parent zone? I do not mean ā€œoffā€ - I mean ā€œstopā€ which also electrically switches off the power to the compressor and therefore is an important mode for me. I can do that in the Airzone app or on the Parent Zone Blueface but as far as I am aware I cannot do that within Homeassistant for now
@bobo2bobo in the following discussion that I opened some time ago I suggest making on/off an independent status from the HVAC mode:
This would allow having the HA Off mode as the Airzone Stop mode.
Anyhow, I will look into this and try to add some service or entity to be able to set the Stop mode from Home Assistantā€¦
@Noltari I get why we canā€™t just turn on/off slaves for now but why couldnā€™t we just remove set_hvac_mode for slaves like I guess you did in your first implementation, as I mentionned here?
Because this was rejected during the review of the Pull Request by the official Home Assistant developers.
I donā€™t know why, but I guess that you could open a new PR changing that to the previous behaviour and see what they have to sayā€¦
@Noltari All right, thanks for the explanation!
@Noltari
Hello.
Iā€™m using your integration since long time and Iā€™m one of the many trying to solve the problem of the Master Slave while remaining in line with HA guidelines.
I think I have found a solution and itā€™s perfectly working but Iā€™d need your help to make it 100% integrated.
In few words, Iā€™d need you to add the attributes provided by the integration under the climate entity two additional attributes which are available from the API call.
They are (their API name):
  • on
  • mode
    Is that possible?
    Iā€™m not wasting your time right now to describe my solution but Iā€™m totally available to provide up to the last detail.
    Hope you can help.
Giacomo
P.S. This is how my frontend looks like now (working)
I can set the mode separately and on/off each zone including the master without affecting the mode
Iā€™m afraid that adding additional attributes to the climate entity will be rejected.
What I can do is create a new switch entity for each zone (both master and slave), which controls the on/off functionality.
And then create a new select entity per master zone which allows changing the HVAC mode on the system without turning on/off that master zone.
@Noltari
I agree with you that adding attributes to the climate entity might be rejected.
Still, the solution that you are proposing would be a big gift for me and the community.
Currently Iā€™m managing to obtain a similar result by using CURL commands but itā€™s clearly a patch.
If you will be so kind to implement the switch and select entity that you suggest I will be very grateful and ready to immediately test it for you.
Iā€™ll then share the code and lovelace interface when they will be properly modified by using the new entities.
Canā€™t waitā€¦ thanks again
Giacomo
Sure, Iā€™ve already started working on it for the local integration:
And I will do it for the Cloud integration too after the local PRs are accepted and merged.
@Noltari thank you for the follow-up.
Local integration is what Iā€™m currently using in my installation, so Iā€™ll be able to test if needed.
I have to confess that I have hard time to understand the ā€œcoded languageā€ used in Github so I didnā€™t add any comment, but if you need any kind of support just let me know.
Giacomo
@Noltari
I just installed 2024.9.0 and, as expected I found the new entity select.xxxx.mode.
It works great !
With small changes to my existing complicated coding I can now change the ā€œmodeā€ of my Airzone installation without touching the current on/off status of the master or slave zone.
I double checked the result of the mode change using the native API command and everything is perfect.
Iā€™m just a bit confused about the other proposed change: the on/off of each zone.
As I already said, Iā€™m not very familiar with the language using in Github, so I donā€™t understand if the second proposed change (Add Airzone switch entities to zones) which is supposed to give control of the zoneā€™s ā€œonā€ entity, is either coming with a future version of HA or achievable in a different way.
Could you be so kind and let me know?
Thanks a lot and thanks again for the new entity that gave me already a lot of relief
Giacomo
That one is still under review and has to be accepted first:
Hello, is it related to this discussion that when the system is in STOP mode I can not change the HVAC mode to heat or cool with the action Set HVAC mode that the integration provides? In my case, if I have the STOP mode selected I need to change previously to heat or cool with the Airzone app for my HA automations to work. I am using the cloud integration.
(post deleted by author)
