Configuration check error, but nothing seems broken
I have been getting this error when running config check for a while now. I am not a linux guru by any stretch and I do not understand why a supported/healty install should present this issue. If I am following correctly, I would need to downgrade urllib to downgrade chardet.
Below is the error message:
[09:56:56] INFO: Please be patient, this might take a few minutes...
ERROR: After October 2020 you may experience errors when installing or updating packages. This is because pip will change the way that it resolves dependency conflicts.
We recommend you use --use-feature=2020-resolver to test your packages with the new resolver before it becomes the default.
aiohttp 3.7.3 requires chardet<4.0,>=2.0, but you'll have chardet 4.0.0 which is incompatible.
System information:
System Health
version: 2021.1.5
installation_type: Home Assistant Supervised
dev: false
hassio: true
docker: true
virtualenv: false
python_version: 3.8.7
os_name: Linux
os_version: 4.19.0-13-amd64
arch: x86_64
timezone: America/Chicago
GitHub API: ok
Github API Calls Remaining: 4967
Installed Version: 1.10.1
Stage: running
Available Repositories: 710
Installed Repositories: 9
host_os: Debian GNU/Linux 10 (buster)
update_channel: stable
supervisor_version: 2021.01.7
docker_version: 20.10.2
disk_total: 218.1 GB
disk_used: 9.5 GB
healthy: true
supported: true
supervisor_api: ok
version_api: ok
installed_addons: Backup Hassio to Google Drive (1.7.2), Dropbox Sync (1.3.0), Duck DNS (1.12.4), FTP (4.0.0), File editor (5.2.0), Log Viewer (0.9.1), RPC Shutdown (2.2), WireGuard (0.4.0), Mosquitto broker (5.1), SSH & Web Terminal (8.0.0), Samba share (9.3.0), TasmoAdmin (0.14.0), motionEye (0.11.0), AdGuard Home (3.0.0), Portainer (1.4.0), Glances (0.10.0), Check Home Assistant configuration (3.6.0), Network UPS Tools (fe20610)
dashboards: 1
mode: storage
resources: 2
Thanks Matt
I also had this exact error. I’ve rebooted a number of times and it’s finally gone away. This situation seems very common as I’ve seen the same effect with other things when doing config checks before upgrades in the recent past. Many hours spent fixing config issues in the past has mean that I still don’t trust the upgrades to be smooth, although they are certainly better than they used to be in the good old days! A clean config check is an absolute “must” for me.
I’m running Home Assistant OS 5.10 on a Raspberry Pi 4 so I’m always surprised that these things show up at all. Anyway - perhaps that’s the way it’s meant to be? reboot and try again!
I’m by far not an expert and I’m having some times the same issues (raspi4 and home assistant in a docker). I noticed that if I get those errors running the Home Assistant configuration check (through the addon), they partly disappear after having performed an update of the hosting os and the remaining errors don’t produce any issue after upgrading Home assistant. That’s exactly what I did today on three different Home Assistant running machines.
I ran the update to the latest version… Error has now changed, but it seems that I always have one in the configuration check.
requests 2.25.1 requires idna<3,>=2.5, but you'll have idna 3.1 which is incompatible.
This is one problem that just keeps on giving. This morning I saw a new update to Core 2021.2.2 was available, ran the config check plugin and I got those messages about idna versions like @mattlward reports. Immediately that after I saw there was now a new Supervisor available. So updated Supervisor, rebooted, and now I’m getting this (again!):
[10:48:10] INFO: Installed Home Assistant 2021.2.2
[10:48:10] INFO: Making a copy of your configuration for checking...
[10:48:19] INFO: Checking your configuration against this version...
[10:52:17] ERROR: The configuration check did not pass!
[10:52:17] ERROR: See the output below for more details.
Testing configuration at /tmp/config
Fatal error while loading config: [Errno 2] No such file or directory: '/usr/local/lib/python3.8/site-packages/chardet-4.0.0.dist-info/METADATA'
Failed config
  General Errors:
    - [Errno 2] No such file or directory: '/usr/local/lib/python3.8/site-packages/chardet-4.0.0.dist-info/METADATA'
Successful config (partial)
So, the rig is:
Operating system: Home Assistant OS 5.11
Supervisor: supervisor-2021.02.6
Existing Core: core-2021.2.1
Testing core ready for upgrade: core-2021.2.2
Hardware: RaspberryPi 4 - 64
I have same issue:
Failed config
  General Errors:
Im running:
System Health
Version core-2021.2.3
Installation Type Home Assistant Supervised
Development false
Supervisor true
Docker true
Virtual Environment false
Python Version 3.8.7
Operating System Family Linux
Operating System Version 5.4.79-v8+
CPU Architecture aarch64
Timezone Europe/Amsterdam
Home Assistant Community Store
MANAGE
GitHub API ok
Github API Calls Remaining 4952
Installed Version 1.11.3
Stage running
Available Repositories 750
Installed Repositories 38
Hass.io
MANAGE
Host Operating System Debian GNU/Linux 10 (buster)
Update Channel stable
Supervisor Version supervisor-2021.02.11
Docker Version 20.10.1
Disk Total 109.7 GB
Disk Used 23.4 GB
Healthy true
Supported true
Supervisor API ok
Version API ok
Was this resolved for you along the way? I still have it (since Feb I believe) for the May update, most current version of Update Check:
INFO:homeassistant.util.package:Attempting install of colorlog==5.0.1
e[01mTesting configuration at /tmp/confige[0m
INFO:homeassistant.util.package:Attempting install of pyatmo==4.2.2
INFO:homeassistant.util.package:Attempting install of hass-nabucasa==0.43.0
INFO:homeassistant.util.package:Attempting install of zeroconf==0.29.0
INFO:homeassistant.util.package:Attempting install of pyroute2==0.5.18
INFO:homeassistant.util.package:Attempting install of aiohttp_cors==0.7.0
INFO:homeassistant.util.package:Attempting install of sqlalchemy==1.4.11
INFO:homeassistant.util.package:Attempting install of unidecode
INFO:homeassistant.util.package:Attempting install of cloudscraper
INFO:homeassistant.util.package:Attempting install of ha-ffmpeg==3.0.2
INFO:homeassistant.util.package:Attempting install of home-assistant-frontend==20210504.0
INFO:homeassistant.util.package:Attempting install of pillow==8.1.2
INFO:homeassistant.util.package:Attempting install of scapy==2.4.5
INFO:homeassistant.util.package:Attempting install of aiodiscover==1.4.0
INFO:homeassistant.util.package:Attempting install of PyNaCl==1.3.0
INFO:homeassistant.util.package:Attempting install of emoji==1.2.0
INFO:homeassistant.util.package:Attempting install of defusedxml==0.6.0
INFO:homeassistant.util.package:Attempting install of netdisco==2.8.2
INFO:homeassistant.util.package:Attempting install of async-upnp-client==0.16.2
INFO:homeassistant.util.package:Attempting install of distro==1.5.0
INFO:homeassistant.util.package:Attempting install of pymodbus==2.5.1
INFO:homeassistant.util.package:Attempting install of psutil==5.8.0
INFO:homeassistant.util.package:Attempting install of jsonpath==0.82
INFO:homeassistant.util.package:Attempting install of xmltodict==0.12.0
INFO:homeassistant.util.package:Attempting install of pyworxcloud==1.2.21
INFO:homeassistant.util.package:Attempting install of mutagen==1.45.1
INFO:homeassistant.util.package:Attempting install of gTTS==2.2.2
e[31mFatal error while loading config:e[0m [Errno 2] No such file or directory: '/usr/local/lib/python3.8/site-packages/idna-3.1.dist-info/METADATA'
e[01;37mFailed confige[0m
  e[01;31mGeneral Errors:e[0m e[31me[31m
    - [Errno 2] No such file or directory: '/usr/local/lib/python3.8/site-packages/idna-3.1.dist-info/METADATA'
e[0m
e[01;37mSuccessful config (partial)e[0m
I am running supervised and had to compile and install Python 3.8 to pass the upgrade test.
Oddly enough after a reboot the error came back in the Check Home Assistant configuration integration.
Same problem here … reboot didn’t work.
