Here is the error I get for the yaml file attached.
Invalid config for [automation]: [entry_id] is an invalid option for [automation]. Check: automation->trigger->0->entry_id. (See ?, line ?). Please check the docs at https://home-assistant.io/components/automation/ Invalid config for [alarm_control_panel.manual]: expected a dictionary for dictionary value @ data[‘triggered’]. Got None. (See ?, line ?). Please check the docs at https://home-assistant.io/components/alarm_control_panel.manual/
Any help would be appreciated.
# Master YAML
homeassistant:
# Name of the location where Home Assistant is running
# Location required to calculate the time the sun rises and sets
latitude: !secret latitude
longitude: !secret longitude
# Impacts weather/sunrise data (altitude above sea level in meters)
elevation: !secret elevation
# metric for Metric, imperial for Imperial
unit_system: imperial
# Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
time_zone: America/New_York
# Customization file
customize: !include customize.yaml
# Show links to resources in log and frontend
# introduction:
# Enables the frontend
frontend:
# Enables configuration UI
config:
#Enable Bluetooth Feature
device_tracker:
- platform: bluetooth_tracker
# API Password
http:
api_password: !secret api_password
# Ring Driveway Camera
# camera:
# - platform: ring
# ring:
# Secert Passwords
# username: !secret ring_name
# password: !secret ring_password
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
# http:
# base_url: example.duckdns.org:8123
# Checks for available updates
# Note: This component will send some information about your system to
# the developers to assist with development of Home Assistant.
# For more information, please see:
# https://home-assistant.io/blog/2016/10/25/explaining-the-updater/
updater:
# Optional, allows Home Assistant developers to focus on popular components.
# include_used_components: true
# Discover some devices automatically
discovery:
# Allows you to issue voice commands from the frontend in enabled browsers
#conversation:
# Enables support for tracking state changes over time
history:
# View all events in a logbook
logbook:
# Enables a map showing the location of tracked devices
map:
# Track the sun
sun:
# Sensors
# Weather prediction
- platform: yr
# Text to speech
tts:
- platform: google
# Cloud
cloud:
# HomeKit
homekit:
# automation: !include automations.yaml
# group: !include groups.yaml
panel_iframe:
configurator:
title: 'Configurator'
url: 'http://192.168.1.7:3218'
icon: mdi:wrench
ide:
title: IDE
icon: mdi:code-brackets
url: http://192.168.1.7:8321
################### Setting up Groups #####################
group:
Garage_Doors:
entities:
- binary_sensor.garage_door_one_closed
- binary_sensor.garage_door_one_opened
- binary_sensor.garage_door_two_closed
- binary_sensor.garage_door_two_opened
- binary_sensor.garage_door_three_closed
- binary_sensor.garage_door_three_opened
Smoke Detectors:
name: Smoke Fire Detectors
entities:
- binary_sensor.smoke_detectors
Glass Breakage Sensors:
name: Glass Breakage Sensors
entities:
- binary_sensor.coffee_glass_breakage
- binary_sensor.den_glass_breakage
- binary_sensor.dinning_glass_breakage
- binary_sensor.family_glass_breakage
- binary_sensor.cellar_bars
Doors:
entities:
- binary_sensor.family_outside_door
- binary_sensor.foyer_outside_door
- binary_sensor.mudroom_garage_door
- binary_sensor.mudroom_outside_door
- binary_sensor.kitchen_outside_door
Motion Detectors:
entities:
- binary_sensor.foyer_motion_detector
Mostures:
name: Water Detection
entities:
- binary_sensor.sump_float_level
# zwave:
# usb_path: /dev/ttyACM0
#switch:
# platform: "Garage Light"
# command_topic: "cmd/sonoff/power"
# state_topic: "stat/sonoff/POWER"
# qos: 1
# payload_on: "ON"
# payload_off: "OFF"
############# Konnected Alarm System Boards ###############
konnected:
access_token: konnected_token
api_host: 'http://192.168.1.7:8123'
devices:
# Board One
- id: 807d3a3e207c
binary_sensors:
- zone: 1
type: door
name: Mudroom Garage Door
- zone: 2
type: door
name: Mudroom Outside Door
- zone: 3
type: door
name: Kitchen Outside Door
- zone: 4
type: door
name: Family Outside Door
- zone: 5
type: door
name: Foyer Outside Door
# Board Two
- id: 807d3a3ea28a
binary_sensors:
- zone: 1
type: window
name: Den Glass Breakage
- zone: 2
type: window
name: Coffee Glass Breakage
- zone: 3
type: window
name: Family Glass Breakage
- zone: 4
type: window
name: Dinning Glass Breakage
- zone: 5
type: motion
name: Foyer Motion Detector
# zone: 6
# type:
# - name:
# Board Three
- id: 807d3a3e2422
binary_sensors:
- zone: 1
type: garage_door
name: Garage Door One Opened
- zone: 2
type: garage_door
name: Garage Door One Closed
- zone: 3
type: garage_door
name: Garage Door Two Opened
- zone: 4
type: garage_door
name: Garage Door Two Closed
- zone: 5
type: garage_door
name: Garage Door Three Opened
- zone: 6
type: garage_door
name: Garage Door Three Closed
# Board Four
- id: 807d3a3ea136
binary_sensors:
- zone: 1
type: smoke
name: Smoke Detectors
- zone: 2
type: moisture
name: Sump Float Level
- zone: 3
type: window
# name:
# - zone: 4
# type:
# name:
# - zone: 5
# type:
# name:
# - zone: 6
# type:
# name:
############# Konnected Alarm System Times ##############
alarm_control_panel:
- platform: manual
code: !secret alarm_code
trigger_time: 300
disarmed:
trigger_time: 0
armed_home:
delay_time: 0
pending_time: 0
armed_away:
delay_time: 60
pending_time: 30
triggered:
pending_time: 0
########### Konnected Alarm System Automation ###########
automation 1:
- alias: Trigger alarm while armed home or away
- platform: state
entry_id: binary_sensor.mudroom_garage_door
to: 'on'
- platform: state
entry_id: binary_sensor.mudroom_outside_door
to: 'on'
- platform: state
entry_id: binary_sensor.kitchen_outside_door
to: 'on'
- platform: state
entry_id: binary_sensor.family_outside_door
to: 'on'
- platform: state
entry_id: binary_sensor.foyer_outside_door
to: 'on'
- platform: state
entry_id: binary_sensor.den_glass_breakage
to: 'on'
- platform: state
entry_id: binary_sensor.coffee_glass_breakage
to: 'on'
- platform: state
entry_id: binary_sensor.family_glass_breakage
to: 'on'
- platform: state
entry_id: binary_sensor.dinning_glass_breakage
to: 'on'
- platform: state
entry_id: binary_sensor.foyer_motion_detector
to: 'on'
- platform: state
entry_id: binary_sensor.smoke_detectors
to: 'on'
- platform: state
entry_id: binary_sensor.garage_door_one_closed
to: 'on'
- platform: state
entry_id: binary_sensor.garage_door_one_open
to: 'on'
- platform: state
entry_id: binary_sensor.garage_door_two_closed
to: 'on'
- platform: state
entry_id: binary_sensor.garage_door_two_open
to: 'on'
- platform: state
entry_id: binary_sensor.garage_door_three_closed
to: 'on'
- platform: state
entry_id: binary_sensor.garage_door_three_open
to: 'on'
- platform: state
entry_id: binary_sensor.sump_float_level
to: 'on'
- platform: state
entry_id: binary_sensor.cellar_bars
to: 'on'
condition:
- condition: state
entity_id: alarm_control_panel.alarm
state: armed_away
- condition: state
state: armed_home
service: alarm_control_panel.alarm_trigger
automation 2:
- alias: 'Send notification when Alarm Triggered'
- platform: state
to: 'triggered'
- service: notify.notify
message: "ALARM! ALARM! - The Home Alarm has been Activated"
