Configuration error for allowlist_external_dirs
Hi All,
I am trying to use the file sensor. It asks to add the file path to allowlist_external_dirs.
So I have made my configuration like below,
homeassistant:
  latitude: !secret ha_latitude
  longitude: !secret ha_longitude
  elevation: !secret ha_elevation
  unit_system: metric
  time_zone: Europe/Berlin
  allowlist_external_dirs:
    - /tmp
  customize: !include customize.yaml
But then I get error
extra keys not allowed @ data['allowlist_external_dirs']
Any idea what am I doing wrong…
Thanks !!!
Did you end up figuring this out? I’m having the same issue.
Home Assistant 0.116.4
Path to configuration.yaml: /config
I tried all of these configurations…
homeassistant:
  customize: !include_dir_merge_named ../customizations/entities
    - "/tmp"
homeassistant:
    - '/tmp'
homeassistant:
    - /tmp
All of these result in a warning in the log of…
WARNING (MainThread) [homeassistant.config] Package homeassistant contains invalid customize
Any solution found please?
same error :
I will add my name to the list receiving this error. I am running version: Home Assistant 0.108.2
At least for version my version (Home Assistant 0.108.2) the older term is the one that works
whitelist_external_dirs:
  - /home/homeassistant/.homeassistant
Mine is also working in 0.117.5 docker
  # Customization file
    - /config/dir/
I have the same problem:
It seems we can only configure the known directories in this section like “config” but not other directories outside of what the home assistant docker process volumes. Why should it be so? I am not able to understand the purpose of this setting?
    - /config  # This one works
    - /home/vijay # This one bombs
Good observation…
@VijayS, why not raising this as an issue in Github…
My tests : This option refuse subfolders
Try only the racine folder.
