Apologies, but I’m getting mixed and matched from multiple of your comments.
I DID try unindenting both those lines, to the same effect.
THEN I posted the Dev Tools - Actions version that was “auto” generated, and it had those indents.
I see, your comment cleared it. Will think then.
Tomorrow will try to simulate your case. Will come back then (if someone else will not help you faster).
Just double checked the Dev Tools - action generated version, and changed the indents as you suggested…and Configuration Error again.
Ok, now we’re in “almost there” hell.
When I use this in Dev Tools -Actions it works:
action: browser_mod.popup
dismissable: true
autoclose: false
content:
type: picture-entity
entity: camera.front_porch
timeout: 30000
device_id: d2ab9242428350849390ec3c451f9bc8
But when I plug that into the automation, it does not. “Configuration error.”
Here’s the automation, which I added the above to. And it errors out.
alias: Front Porch Camera Motion
description: ""
triggers:
- type: motion
device_id: 267e7fc35eadc83d88626913b2161f1d
entity_id: 413296f02876d4de64d8e684e0f0eb67
domain: binary_sensor
metadata:
secondary: false
trigger: device
conditions: []
actions:
- action: browser_mod.popup
metadata: {}
dismissable: true
autoclose: false
browser_id:
- d2ab9242428350849390ec3c451f9bc8
title: Front Porch Motion
content:
dismissable: true
autoclose: false
content:
timeout: 30000
target: null
mode: single
So now when I test the automation, this works:
description: ""
triggers:
- type: motion
metadata:
secondary: false
trigger: device
conditions:
- condition: state
entity_id: media_player.bar_ipad
state:
- "on"
content:
timeout: 15000
mode: single
BUT. I get the dread “Message malformed. Extra keys not allowed @Data [data]” when I try to save it.
Ugh.
So, I messed with it over and over until it both saved and worked:
description: prototype for all camera motion
triggers:
- type: motion
metadata:
secondary: false
trigger: device
conditions:
- condition: state
state:
- "on"
actions:
metadata: {}
dismissable: true
autoclose: false
content:
timeout: 30000
target: null
mode: single
The line after “target” should be indented for sure.
@DifferentComputers
Got to a PC, installed browser_mod, completely filed, does not work.
The simplest example:
type: button
entity: sun.sun
tap_action:
action: call-service
service: browser_mod.popup
title: xxx
content:
entity: camera.demo_camera
browser_id: THIS
user_id: THIS
Pressing on a button does nothing.
No errors, no record in Log.
So, no idea…
Docs for this plugin contain plenty of mixed info but no examples.
Sorry, could not help you.
Will uninstall this.
P.S. Docs does not contain info about a “target” option for browser_mod.
Also, “dev tools - actions” does not suggest to fill this field. Probably this option should not be here.
