I am struggling with the errors I am getting?
Configuration invalid CHECK CONFIG
Invalid config for [alarm_control_panel]: required key not provided @ data[‘platform’]. Got None. (See /config/configuration.yaml, line 161). Please check the docs at https://home-assistant.io/components/alarm_control_panel/ Invalid config for [alarm_control_panel]: required key not provided @ data[‘platform’]. Got None. (See /config/configuration.yaml, line 161). Please check the docs at https://home-assistant.io/components/alarm_control_panel/
Configuration.yaml
homeassistant:
# Name of the location where Home Assistant is running
# Location required to calculate the time the sun rises and sets
latitude: xx.xxxxxx
longitude: -xx.xxxxxx
# Impacts weather/sunrise data (altitude above sea level in meters)
elevation: xxx
# metric for Metric, imperial for Imperial
unit_system: imperial
# Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
time_zone: America/New_York
# Customization file
customize: !include customize.yaml
# Show links to resources in log and frontend
introduction:
# Enables the frontend
frontend:
# Enables configuration UI
config:
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
# http:
# base_url: example.duckdns.org:8123
# Checks for available updates
# Note: This component will send some information about your system to
# the developers to assist with development of Home Assistant.
# For more information, please see:
# https://home-assistant.io/blog/2016/10/25/explaining-the-updater/
updater:
# Optional, allows Home Assistant developers to focus on popular components.
# include_used_components: true
# Discover some devices automatically
discovery:
# Allows you to issue voice commands from the frontend in enabled browsers
conversation:
# Enables support for tracking state changes over time
history:
# View all events in a logbook
logbook:
# Enables a map showing the location of tracked devices
map:
# Track the sun
sun:
# Sensors
# Weather prediction
- platform: yr
# Text to speech
tts:
- platform: google
# Cloud
cloud:
group: !include groups.yaml
############# Konnected Alarm System Boards ###############
konnected:
access_token: konnected_token
# api_host: http://192.168.1.3:8123
devices:
- id: 827d3a6e6507
binary_sensors:
- zone: 1
type: door
name: 'Mudroom Garage Door'
- zone: 2
type: door
name: 'Mudroom Outside Door'
- zone: 3
type: door
name: 'Kitchen Outside Door'
- zone: 4
type: door
name: 'Family Outside Door'
- zone: 5
type: door
name: 'Foyer Outside Door'
- id: 827d3a6eaa07
binary_sensors:
- zone: 1
type: window
name: 'Den Glass Breakage'
- zone: 2
type: window
name: 'Coffee Glass Breakage'
- zone: 3
type: window
name: "Family Glass Breakage"
- zone: 4
type: window
name: 'Dinning Glass Breakage'
- zone: 5
type: motion
name: 'Foyer Motion Detector'
- id: 827d3a6e6707
binary_sensors:
- zone: 1
type: smoke
name: 'Smoke Detector in Upper Hall'
- zone: 2
type: smoke
name: 'Smoke Detector in Master Bedroom'
- zone: 3
type: smoke
name: 'Smoke Detector in Mudroom'
- zone: 4
type: smoke
name: 'Fire Detector in Upper Hall'
- zone: 5
type: smoke
name: 'Fire Detector in Master Bedroom'
- zone: 6
type: smoke
name: 'Fire Detector in Mudroom'
- id: 827d3a6e3107
binary_sensors:
- zone: 1
type: garage_door
name: 'Garage Door One Opened'
- zone: 2
type: garage_door
name: 'Garage Door One Closed'
- zone: 3
type: garage_door
name: 'Garage Door Two Opened'
- zone: 4
type: garage_door
name: 'Garage Door Two Closed'
- zone: 5
type: garage_door
name: 'Garage Door Three Opened'
- zone: 6
type: garage_door
name: 'Garage Door Three Closed'
- id: 827d3a6e4207
binary_sensors:
- zone: 1
type: moisture
name: 'Sump Float Level'
- zone: 2
type: window
alarm_control_panel:
- platform: manual
code: alarm_code
trigger_time: 300
disarmed:
trigger_time: 0
armed_home:
delay_time: 0
pending_time: 0
armed_away:
delay_time: 60
pending_time: 30
triggered:
pending_time: 0
- alias: Trigger alarm while armed home or away
- platform: state
entry_id: binary_sensor.mudroom_garage_door
to: 'on'
- platform: state
entry_id: binary_sensor.mudroom_outside_door
to: 'on'
- platform: state
entry_id: binary_sensor.kitchen_outside_door
to: 'on'
- platform: state
entry_id: binary_sensor.family_outside_door
to: 'on'
- platform: state
entry_id: binary_sensor.foyer_outside_door
to: 'on'
- platform: state
entry_id: binary_sensor.den_glass_breakage
to: 'on'
- platform: state
entry_id: binary_sensor.coffee_glass_breakage
to: 'on'
- platform: state
entry_id:
to: 'on'
- platform: state
entry_id: binary_sensor.dinning_glass_breakage
to: 'on'
- platform: state
entry_id: binary_sensor.foyer_motion_detector
to: 'on'
- platform: state
entry_id: binary_sensor.smoke_detector_in_upper_hall
to: 'on'
- platform: state
entry_id: binary_sensor.smoke_detector_in_master_bedroom
to: 'on'
- platform: state
entry_id: binary_sensor.smoke_detector_in_mudroom
to: 'on'
- platform: state
entry_id: binary_sensor.fire_detector_in_upper_hall
to: 'on'
- platform: state
entry_id: binary_sensor.fire_detector_in_master_bedroom
to: 'on'
- platform: state
entry_id: binary_sensor.fire_detector_in_mudroom
to: 'on'
- platform: state
entry_id: binary_sensor.garage_door_one_closed
to: 'on'
- platform: state
entry_id: binary_sensor.garage_door_one_open
to: 'on'
- platform: state
entry_id: binary_sensor.garage_door_two_closed
to: 'on'
- platform: state
entry_id: binary_sensor.garage_door_two_open
to: 'on'
- platform: state
entry_id: binary_sensor.garage_door_three_closed
to: 'on'
- platform: state
entry_id: binary_sensor.garage_door_three_open
to: 'on'
- platform: state
entry_id: binary_sensor.sump_float_level
to: 'on'
- platform: state
entry_id: binary_sensor.cellar_bars
to: 'on'
condition:
condition: or
conditions:
- condition: state
entity_id: alarm_control_panel.alarm
state: armed_away
- condition: state
state: armed_home
service: alarm_control_panel_.alarm_trigger
- alias: Alarm Triggered
- platform: state
to: 'triggered'
- service: notify.notify
message: "!Alarm Triggered!"
Thanks for your input.
