My configuration file is fine when I’m on my home network and I setup cloud access which works fine but the configuration file is blank. Can I not access the file via the cloud or is there a setting I need to modify?
I’m assuming you mean configuration.yaml?
How are you trying to access the file? Configurator Add-On?
Yes the configuration.yaml is correct. I’m just trying to use the configurator Add-on in home assistant. I signed up for the cloud service and can log in to home assistant away from my network and view everything except the configuration.yaml. It’s just empty and won’t let me type anything in it. Should I be using something other than the built in configurator Add-on?
