Configuration Flogger Node
Hi there,
I’m stuck at the correct file path (log dir) I have to enter fr a working node. Can you help me out?
no one? :frowning: just don’t know what directory to enter
I haven’t used that node. But the file node needs this path to write in the main config folder
Unfortunately that doesn’t work :frowning:
Doesn’t work where the standard write node or the other one? I think I had to create a blank text file in the location first for it to work.
I don’t specify a path, just a file name.
Mine end up in: \config\www\flogger\
I have mine pointed to
/config/node-red/logs
