Configuration - General, map remains empty
I removed some configuration from the configuration.yaml, to configure this in the UI (which is now available). Somehow, the map becomes grey if I remove longitude configuration from the yaml file. If I add it the whole configuration is greyed out in the UI. How can I fix this?
I don’t use it but from reading other threads here the solution is to zoom out…a lot…
For some reason the marker starts out in the middle of the ocean, hence, the grey background because it’s all water.
If you zoom all the way out you will eventually see “land, ho!” :laughing:
I believe it starts from latitude=longitude=0. It should be zoomed out to the whole world, but silliness prevails.
you’re right. I should have realized that.
not to bump this, but still doing so, sorry.
I find the Map to behave like that, while the configuration.yaml has lat/long and the location of the HA instance in configuration/general is fine.
Any hints how to adjust the zoom level for the Map (left side menu)?
only pointer I have is a GDACS sensor, around which the Map now centers:
zooming 15 times results in:
