Hello all,
I just installed my Home Assistance instance (Home Assistant Core 2022.5.4 / Home Assistant Supervisor 2022.05.2 / Kernel version 5.15.32-v8+ / Agent version 1.2.2) via Docker on a Raspian Lite OS x64 11 (Bullseye) on my Raspberry Pi 4 8Gb.
The latter is equipped with a ConBee II and works very well for the moment.
However, I wanted to connect my SwitchBot via Bluetooth to my Home assistant. Obviously I got an error when trying to install the SwitchBot 3rd party module in Home Assistant, it can’t find bluetooth.
So I went to my Raspbian in ssh and I installed the library to activate bluetooth:
The bluetooth works perfectly but back in my Home Assistant Board, impossible to install the SwitchBot module, it still does not recognize the bluetooth…
Searching the web, I found people who sent their docker container as a Host at the risk of no longer accessing Home Assistant, others who use usb bluetooth dongles and it seems to work well but no one does not give models or installation procedures.
Apparently on the raspberry pi 4b it is a Cypress CYW43455 compatible with Bluetooth 5 and BLE. Anyone have an idea on how to get it recognized in docker? since it is already recognized in raspbian 11…
Not an idea regarding the docker recognition, but if you have an esp32 laying around, OpenMQTTGateway supports now the switchbot s1 with auto discovery.
I went over this and it didn’t work for me. It seems that it is actually important to use some specific ESP32. Not all of the are the same. See for example this:
I bought one more ESP32, hopefully the correct version now.
