smile
August 16, 2019, 11:27pm
1
light.yaml
file is in packages directory but system cant read this file . I am tried to place packages: !include_dir_named packages/
in different places in configuration file.
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
http:
base_url: ********.duckdns.org
ssl_certificate: /ssl/fullchain.pem
ssl_key: /ssl/privkey.pem
# Text to speech
tts:
- platform: google_translate
group: !include groups.yaml
input_boolean: !include include/input_boolean.yaml
input_number: !include include/input_number.yaml
input_select: !include include/input_select.yaml
sensor: !include sensors.yaml
zone: !include zones.yaml
if i place homeassistent:
on top in configuration.yaml
file then face a invalid configuration.
Packages is a “subset” of homeassistant:
so it needs to be listed under that domain.
As your error message states, flash is NOT a valid option for mqtt light.
As indicated by the page that the error message tells you to go to, you need to use template or json
Don’t indent packages under default_config:
homeassistant:
default_config:
smile
August 17, 2019, 12:43am
4
Just remove the line flash:
from your mqtt light config and test…why is this hard?
smile
August 17, 2019, 1:09am
6
flamingm0e:
e flash:
same error after remove the line.
light:
platform: mqtt
schema: template
command_topic: "home/gjesterom_lysT3/set"
command_on_template: "on"
command_off_template: "off"
You keep showing bits and pieces of your config…if you want help you need to share more information.
smile
August 17, 2019, 1:20am
8
I just use one light in light.yaml for define the error. before the new installation, all lights were in working condition here is my old light.yaml
light:
- platform: mqtt
command_topic: "cmnd/Ganganlys T1/power"
state_topic: "stat/Gangan lys T1/POWER"
qos: 1
payload_on: "ON"
payload_off: "OFF"
retain: true
# GJESTEROM LYS
- platform: mqtt
command_topic: "cmnd/gjesterom_lysT3/power"
state_topic: "stat/gjesterom_lysT3/POWER"
qos: 1
payload_on: "ON"
payload_off: "OFF"
retain: true
# SOVEROM LYS
- platform: mqtt
command_topic: "cmnd/soverom_lysT3/power"
state_topic: "stat/soverom_lysT3/POWER"
qos: 1
payload_on: "ON"
payload_off: "OFF"
retain: true
# SPISEBORD LYS
- platform: mqtt
command_topic: "cmnd/Spisebord_lys/power"
state_topic: "stat/Spisebord_lys/POWER"
qos: 1
payload_on: "ON"
payload_off: "OFF"
retain: true
# STUE LYS
- platform: mqtt
command_topic: "cmnd/stue_lysT2/power"
state_topic: "stat/stue_lysT2/POWER"
qos: 1
payload_on: "ON"
payload_off: "OFF"
retain: true
Based on your error messages, you have a problem with an mqtt light somewhere and you have defined a flash option. Find that mqtt light and fix it.
smile
August 17, 2019, 1:46am
10
Light working in configuration.yaml, but if i put light.yam
l file in config/packages then not working more.
default_config:
http:
base_url: XXXXXXX.duckdns.org
# Text to speech
tts:
light:
- platform: mqtt
qos: 1
payload_on: "ON"
payload_off: "OFF"
retain: true
I suppose you just don’t want to post your packages yaml?
How are you including light.yaml in the package you’re creating?
What does the file structure look like?
smile
August 17, 2019, 2:21pm
12
This is my new hassio installation. In packages folder is only light.yaml which i posted here. light.yaml
I just create a packages folder in config and move my light.yaml file in packages folder.
light.yaml file path: /config/packages/light.yaml
and in configuration.yaml like below.
default_config:
http:
# Text to speech
tts:
I tried also like
homeassistant:
default_config:
http:
# Text to speech
tts:
default_config:
That’s wrong
homeassistant:
Syntactically this is correct but how does the packages process the files located in the directory? I don’t see where you’ve defined a package.
30 seconds with the documentation says you’re not creating a package, but trying to dump your yaml in a packages directory and not define anything
