On my old server the AddOn ioBroker runs well. Now I must change to a new Server with a new IP-Adress. After install a backup all implentation, Hacs and AddOn works well.
But with ioBroker I have problems. The addOn ist green but I can’t open the UI! So I unistalled the AddOn, restart HA and installed the AddOn new.
eval: iobroker update && iobroker upgrade self
is done.
The status is green, but the log shows errors:
--------------- 2023-11-05 14:58:24 ---------------
----- Welcome to your ioBroker-container! -----
----- Startupscript is now running. -----
----- Please be patient! -----
----- Debugging information -----
----- System -----
----- arch: x86_64 -----
----- Versions -----
----- image: -----
----- node: v12.21.0 -----
----- npm: 6.14.11 -----
----- ENV -----
----- SETGID: 1000 -----
----- SETUID: 1000 -----
----- Step 1 of 5: Preparing container -----
Registering maintenance script as command.
Done.
----- Step 2 of 5: Detecting ioBroker installation -----
Existing installation of ioBroker detected in /opt/iobroker.
----- Step 3 of 5: Checking ioBroker installation -----
(Re)Setting folder permissions (This might take a while! Please be patient!)...
Done.
Fixing "sudo-bug" by replacing sudo in iobroker with gosu...
Done.
internal/modules/cjs/loader.js:818
throw err;
Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
at Function.Module._resolveFilename (internal/modules/cjs/loader.js:815:15)
at Function.Module._load (internal/modules/cjs/loader.js:667:27)
at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:60:12)
at internal/main/run_main_module.js:17:47 {
code: 'MODULE_NOT_FOUND',
requireStack: []
/opt/scripts/iobroker_startup.sh: Zeile 205: [: !=: Einstelliger (unärer) Operator erwartet.
----- Step 4 of 5: Applying special settings -----
Some adapters have special requirements/ settings which can be activated by the use of environment variables.
For more information take a look at readme.md on Github!
----- Step 5 of 5: ioBroker startup -----
Starting ioBroker...
Running 'eval' commands
throw err;
requireStack: []
throw err;
Error: Cannot find module '/data/iobroker/node_modules/iobroker.js-controller/controller.js'
requireStack: []
What is wrong? What can I do?
