Configuration not found
Hello everyone,
I am trying to integrate the add-on MQTT Siemens S7 Connector and fail to load the configuration.
I have already tried the configuration in the following folders:
/homeassistant/addon_configs/xxxxxxxx_mqtt-s7-connector/config.yaml
/homeassistant/config.yaml
/homeassistant/config_files/config.yaml
/homeassistant/configfiles/config.yaml
/homeassistant/config/config.yaml
I always get an error that the configuration is not found.
What am I doing wrong here?
Please find attached the complete error message.
Add-on: MQTT Siemens S7 Connector
MQTT Siemens S7 connector to integrate Siemens PLC’s with Home Assistant
Add-on version: 1.0.8
You are running the latest version of this add-on.
System: Home Assistant OS 14.2 (amd64 / generic-x86-64)
Home Assistant Core: 2025.3.0
Home Assistant Supervisor: 2025.03.2
s6-rc: info: service base-addon-banner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service base-addon-log-level: starting
s6-rc: info: service fix-attrs successfully started
Log level is set to WARNING
s6-rc: info: service base-addon-log-level successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service init: starting
s6-rc: info: service init successfully started
s6-rc: info: service legacy-services: starting
s6-rc: info: service legacy-services successfully started
[email protected] start
node index.js --addonversion 1.0.8 --config /config/config.yaml --loglevel=4
INIT ## log level is set to: 4
2025-3-8 9:13:57 ## ERROR ## Config file ‘/config/config.yaml’ not found
/usr/src/mqtt-s7-connector/service_functions.js:57
throw new Error(msg);
Error: Config file ‘/config/config.yaml’ not found
at Object.error (/usr/src/mqtt-s7-connector/service_functions.js:57:9)
at Object.config (/usr/src/mqtt-s7-connector/config_handler.js:40:20)
at Object. (/usr/src/mqtt-s7-connector/index.js:12:31)
at Module._compile (node:internal/modules/cjs/loader:1550:14)
at Object…js (node:internal/modules/cjs/loader:1702:10)
at Module.load (node:internal/modules/cjs/loader:1307:32)
at Function._load (node:internal/modules/cjs/loader:1121:12)
at TracingChannel.traceSync (node:diagnostics_channel:322:14)
at wrapModuleLoad (node:internal/modules/cjs/loader:219:24)
at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:170:5)
Node.js v23.2.0
s6-rc: info: service legacy-services: stopping
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service init: stopping
s6-rc: info: service mqtt-s7-connector: stopping
s6-rc: info: service init successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service mqtt-s7-connector successfully stopped
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service base-addon-log-level: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service base-addon-log-level successfully stopped
s6-rc: info: service base-addon-banner: stopping
s6-rc: info: service base-addon-banner successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
I have no clue about this integration but if this is how you reference files in it it is wrong. The file you want is configuration.yaml, not config.yaml.
Hello MIngo,
Welcome to the HA forum!
I would contact the Add-on’s author in the place you got the software from.
Some years ago now HA did some folder structure changes concerning /config and /homeassistant. Your software’s author may not have caught up to that yet. I would check there for a work around.
This might I suspect be a file that is specific to this software that the install person needs to make? Would have to look in the repo.
Add-ons doing stuff with the configuration.yaml would be out of the norm.
thx for your answers.
I solved the problem.
Root cause was - my file editor.
With this setting I am able to find the right directory.
Enforce Basepath
If set to true, access is limited to files within the /config directory.
