I’m having trouble configuring or adjusting the FIBARO System FGRGBWM441 RGBW Controller and its RGBW Led strip. The led strip has 4 leds (Red, Green, Blue, White). Each colour is shown as a switch in Home-Assistant.
But I dont know how to adjust it to get the colour i want, if I switch it on via the main switch (next to the name) it turns on all the leds, when i turn on one colour it shows that specific colour. But i cant mix it. Ideally I would like a switch which sets the colour I would like.
I have set the parameters of the Controller to following
1 = ALL ON active/ ALL OFF active
6 = Normal(RGBW) - COLOR_CONTROL_SET
8 = MODE 2 - Constant Time (RGB/RGBW only…)
11 = 67
14 = 8738 (momentary, normal mode)
Rest of the parameters has the default values.
For the moment I don’t have anything connected to the inputs but I would like to have switch connected, that controlls manual on/off
As I wrote above, I would like to be able to control the on/off of the LED-strip from one switch/button, SW
And also to be able to control the colur of the LED-strip in a simple way.
For control the led strip with switch you have to put it from the analog outputs to the neutral wire after the 12/24v VDC Adapter. Then, with one push the led strip will light and if you keep pushed the brightness will change.
Okay, this is what I want to achive.
The LED-strip should both be controlled from one switch on/off, brightness (keep pressed) or from the HA frontend.
The color of the RGBW LED-strip should in the first hand be controlled from the HA fronted by one wheel or something easy controlled, i.e when the LED-strip is turned of it should remember this color. Next time when it is turned on it should have the same color as last time.
If it is possible I also would like to contol the color from a second switch, i.e if the switch is pressed the LED-strip should walk through all the colors and when the switched is released the shining color should be selected.
Did you understand ?
Hi fran_blade,
Yes I already have my Fibaro RGBW Controller connected to the z-wave network.
I can see it and I have several switches in the HA frontend, see figure
But how do I configure the Fibaro RGBW Controller, parameters to get the right performance as I want.
Did anyone figure this out, I’ve just installed a Fibaro RGBW controller and I have 6 (six) switches, including the red, green, blue and white channels. However I’m unable to set parameters that either allow for the unit to be controlled by a single momentary switch or use/set any arbitrary RGB or HS colour.
I have tried a few combinations, but there are too many to try them all.
I have tried param nr14 set to (default) 4368 and single input mode 8738.
Would love to see this working better than is currently does, any help really appreciated.
I have the same problem and I hade not solved it yet.
This problem has been paused for me, but I’m really interested to find a solution for it.
If you solved the problem, please let me know.
No I have not solved this problem yet.
I have had other problem, but I really would like to found a solution to this problem.
Please let me know if you found a solution.
Hi all, I’m having some issues with my RGBW as well
Everything works well if I control via HA or Alexa. However the swicth on the wall (momentary single switch) which is supports to turn on and off seems to turn on the white and blue channels and then off only the white channel (i think, it’s quite odd…)
What’s really odd is that the press of the button doesn’t seem to send any state change to HA at all, so I can’t take any action on that press either…
Bit lost how to fix it so wondering if anyone has any ideas!?
