Configuration of Nibe Heatpump Integration - how to set holiday parameters
I have managed to setup the Nibe Integration via modbus. I have a SMO40 unit connected via the Nibe modbus40 module and a modbus gateway. Everything seems to be working fine so far.
What I am now looking for are the entities linked to the holiday mode (eg, start and end date, temperature settings). Can someone let me know the respective entity names? Or if they are not there is there a way to configure the respective modbus registers manually?
Thanks a lot
Peter
