Hey folks,
I ordered this 2.4" TFT ILI9341Display on Aliexpress, from the discription and the datasheet it says, the IC is the ILI9341:
After testing the display with esphome, only a square of 240x240 pixel are displayed correctly. And the color “red” and “blue” are swapped.
spi:
clk_pin: GPIO18
mosi_pin: GPIO23
miso_pin: GPIO19
display:
- platform: ili9xxx
model: ILI9341
cs_pin: GPIO5 #not in docs
dc_pin: GPIO27
reset_pin: GPIO33
lambda: |-
it.print(0, 0, id(my_font), id(color_red), TextAlign::TOP_LEFT, "red");
it.print(100, 100, id(my_font), id(color_green), TextAlign::TOP_LEFT, "green");
it.print(200, 200, id(my_font), id(color_blue), TextAlign::TOP_LEFT, "blue");
After changing to model: TFT 2.4R
worked over the full screen with 320x240 pixel, but the colors “red” and “blue” are still swapped.
After a lot of testing, I used this Arduino GFX Library with the same Pin configuration on my ESP32 and noticed, that my Drive IC is a ST7789
Now I try the ST7789V Component, but got it only working with the model: TTGO TDisplay 135x240
. The problem is, that this too small for display.
So I tried the model: Costum
display:
- platform: st7789v
model: Custom
height: 320
offset_height: 0
width: 240
offset_width: 0
cs_pin: GPIO5
dc_pin: GPIO27
reset_pin: GPIO33
lambda: |-
I got this in my log: [I][logger:326]: Log initialized[C][ota:473]: There have been 1 suspected unsu - Pastebin.com
The buffer can’t be allocated.
So someone got that kind of IC running or got and suggestion what to do? Or a recommendation for 2.4" display with a small PCB overhang around the Display?
Thanks and greeting!
