Configuration of xiaomi gateway - help needed
hi,
i posted this in the hass.io forum - i think i was wrong there.
i tried to integrate the xiaomi gateway into my hass.io installtion by following this tutorial:
home-assistant.io1
Xiaomi Gateway (Aqara)
Instructions for how to integrate the Xiaomi Gateway (Aqara) within Home Assistant.
i also tried all the hints at the end of the page. unfortunately it did not work, the log files shows this:
2017-10-03 00:29:42 WARNING (MainThread) [homeassistant.setup] Setup of xiaomi_aqara is taking over 10 seconds.
2017-10-03 00:30:22 ERROR (SyncWorker_12) [homeassistant.components.xiaomi_aqara] No gateway discovered
2017-10-03 00:30:22 ERROR (MainThread) [homeassistant.setup] Setup failed for xiaomi_aqara: Component failed to initialize.
my config file looks that way:
xiaomi_aqara:
discovery_retry: 10
gateways:
    mac:
    key: 166EFD08A226xxxx
i can see the gateway in the admin-area of the rooter, it is on the same network as all other devices.
do you have any hints why this does not work?
Check this way
xiaomi_aqara:
  gateways:
    - mac:
And use lowercase in your key for gateway.
I had the gateway connected with config variables such as host, mac, key, interval… it worked and I was abale to customise my sensors…
When I rebooted it said it could not connect…
have been trying everything leaving on the key field with lowercase in the key (15adca…) nothing still wont connect.
I can conenct via the app and my router is telling me that the device is online…
any ideas?
