I have the Android Home Assistant app, and in it, I do not see the option to choose Configuration and make edits to the Automations. This would be very helpful so I can be downstairs modifying an automation on my phone and then test it, without going back and forth to my computer to make edits…
Options under teh User Profile like “advanced mode” are on a per device basis. So if you set it on the desktop you need to set it on the app and if you use a browser on mobile you need to set it there too.
I’m having this problem now. I have a Google 3a Pixel XL. I can’t see the App configuration. I have Advance mode activated in HA. The solution is:
“I had to toggle Advanced mode off and back on again in the mobile app to get everything to show up…”
Are you saying that you have to go to Advanced Mode in HA on the mobile App and then toggle off/on in order for the App configuration to appear?
Thanks for replying jwadsley. I was a little concerned that you might say that. I tried it but it did not work for me. How did you get your Android phone/Chrome broswer to “Advanced Mode”? That may be the one part I’m doing differently.
In Chrome / Firefox I go to the bottom of the hamburger menu on the left down to my name, and click on it. Then in the middle section there is an Advanced Mode toggle that I toggled on and back off. I had to do this same thing in the app as well.
I found it. I went into Configuration on the mobile and the Companion app configuration is in there.
When you find yourself in a hole, stop digging… I’ll stop digging.
