I am successfully using a home assistant configuration with distributed files so that my configuration.yaml looks like this:
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
homeassistant:
allowlist_external_dirs:
- /share
# Load packages
packages: !include_dir_named integrations
customize: !include customize.yaml
somehow I cannot get the yaml based HomeKit bridge configuration to work.
when I create a homekit.yaml file in the integrations directory with the content
homekit:
I get an error message after restart
Invalid config
The following integrations and platforms could not be set up:
homekit
Please check your config.
So my question is where to add the “homekit:” line to get this to work.
