Configuration Rflink
i’m pretty new in HomeAssistant and i would try to use my Rflkink and my 433mhz sensors.
( Sorry for my frenchie bad english ).
I have created the line in configuration.yaml for rflink
And i have created those lines, in sensor.yaml ( and tried in configuration.yaml )
##Capteurs Rflink
# Sonde Temp, et Hygrométrie Oregon
  - platform: rflink
    automatic_add:false
    devices:
      sensor.oregontemphygro_3287e_temp
      sensor_type: temperature
      oregontemphygro_3287e_hum
      sensor_type: humidity
      oregontemphygro_3287e_hstatus
      sensor_type: humidity_status
      oregontemphygro_3287e_bat
      sensor_type: battery
      oregontemphygro_3287e_update_time
And i have errors when i want to reboot my Hass. The documentation won’t helped me in that problem.
I have a motion sensor too, and i have tried to make a file for him too :in a binary_sensor.yaml
##Liste Capteur Binaire
#Capteur Alarme Etiger
# Alarme Etiger
  - platform: rflink
    devices:
    chuango_2ebf59_02:
    name: Capteur mouv salon
    device_class: motion
    off_delay: 5
But i could make nothing work…
Can someone have a solution ?
i have a chacon dio 54785, impossible to find her with my rflink
Thanks for reading, and for help…
Without a correct formating it will be very dificult to help you.
Use 3 ` at code begin and end to format
type or paste code here
@javicalle
It’s work ?
Take another look to the config examples at the documentation:
Same here:
It’s all YAML format. Spaces and identation are important.
@javicalle
I have trieds this :
  - platform: rflink
    automatic_add:false
    devices:
      oregontemphygro_22866_temp:
      oregontemphygro_22866_hum:
      oregontemphygro_22866_hstatus:
      oregontemphygro_22866_bat:
      oregontemphygro_22866_update_time:
And it’s put me un error.
can not read a block mapping entry; a multiline key may not be an implicit key at line 39, column 12:
        devices:
For this one
# Alarme Etiger
binary_sensor:
  - platform: rflink
    devices:
      chuango_2ebf59_02:
        off_delay: 5
No errors found, but it’s wont give me acces to him in entities …
So i could not use him in automation …
Edit My bad the motion sensor works fine
Edit:
  - platform: rflink
    devices:
#     oregontemphygro_22866_update_time:
#       sensor_type: ???
#       name: Update Time
There is only one errors left, i don’t know what type to use, to show update time …
I have found my errors :), but still this one left.
Anyone know how to add, a Dio Chacon 54785
Anyway thanks for your help @javicalle
Now there is another problem on oregon …
i have no data coming, and when i look in the debug log, i have some data from him …
2020-07-29 00:21:13 DEBUG (MainThread) [rflink.protocol] got packet: 20;05;F007_x;ID=faf82;TEMP=80ee;HUM=48;BAT=OK;
2020-07-29 00:21:13 DEBUG (MainThread) [rflink.protocol] decoded packet: {'node': 'gateway', 'protocol': 'f007_x', 'id': 'faf82', 'temperature': -23.8, 'temperature_unit': '°C', 'humidity': 48, 'humidity_unit': '%', 'battery': 'ok'}
2020-07-29 00:21:13 DEBUG (MainThread) [rflink.protocol] got event: {'id': 'f007_x_faf82_temp', 'sensor': 'temperature', 'value': -23.8, 'unit': '°C'}
2020-07-29 00:21:13 DEBUG (MainThread) [homeassistant.components.rflink] event of type sensor: {'id': 'f007_x_faf82_temp', 'sensor': 'temperature', 'value': -23.8, 'unit': '°C'}
2020-07-29 00:21:13 DEBUG (MainThread) [homeassistant.components.rflink] entity_ids: ['sensor.f007_x_faf82_temp']
2020-07-29 00:21:13 DEBUG (MainThread) [homeassistant.components.rflink] passing event to sensor.f007_x_faf82_temp
2020-07-29 00:21:13 DEBUG (MainThread) [rflink.protocol] got event: {'id': 'f007_x_faf82_hum', 'sensor': 'humidity', 'value': 48, 'unit': '%'}
2020-07-29 00:21:13 DEBUG (MainThread) [homeassistant.components.rflink] event of type sensor: {'id': 'f007_x_faf82_hum', 'sensor': 'humidity', 'value': 48, 'unit': '%'}
2020-07-29 00:21:13 DEBUG (MainThread) [homeassistant.components.rflink] entity_ids: ['sensor.f007_x_faf82_hum']
2020-07-29 00:21:13 DEBUG (MainThread) [homeassistant.components.rflink] passing event to sensor.f007_x_faf82_hum
2020-07-29 00:21:13 DEBUG (MainThread) [rflink.protocol] got event: {'id': 'f007_x_faf82_bat', 'sensor': 'battery', 'value': 'ok', 'unit': None}
2020-07-29 00:21:13 DEBUG (MainThread) [homeassistant.components.rflink] event of type sensor: {'id': 'f007_x_faf82_bat', 'sensor': 'battery', 'value': 'ok', 'unit': None}
2020-07-29 00:21:13 DEBUG (MainThread) [homeassistant.components.rflink] entity_ids: ['sensor.f007_x_faf82_bat']
2020-07-29 00:21:13 DEBUG (MainThread) [homeassistant.components.rflink] passing event to sensor.f007_x_faf82_bat
2020-07-29 00:21:13 DEBUG (MainThread) [rflink.protocol] got event: {'id': 'f007_x_faf82_update_time', 'sensor': 'update_time', 'value': 1595974874, 'unit': 's'}
2020-07-29 00:21:13 DEBUG (MainThread) [homeassistant.components.rflink] event of type sensor: {'id': 'f007_x_faf82_update_time', 'sensor': 'update_time', 'value': 1595974874, 'unit': 's'}
2020-07-29 00:21:13 DEBUG (MainThread) [homeassistant.components.rflink] entity_ids: ['sensor.f007_x_faf82_update_time']
2020-07-29 00:21:13 DEBUG (MainThread) [homeassistant.components.rflink] passing event to sensor.f007_x_faf82_update_time
How it’s possible ?
I think that you can configure it without sensor_type :
When i put without sensor type, i can’t reboot hass :\
Invalid config for [sensor.rflink]: required key not provided @ data[‘devices’][‘oregontemphygro_22866_update_time’][‘sensor_type’]. Got None. (See ?, line ?).
Ummm, you are rigth…
Try with:
      sensor_type: timestamp
RFLink sometimes detect the same device with multiples IDs.
Because of this, there is an aliases attribute:
  - platform: rflink
    devices:
        aliases:
          - f007_x_faf82_temp
But, be carefull, because although it may seem like it, the signal does not come from the same device. I recommend checking it twice before adding an alias to your device.
If I am not mistaken, the Dio Chacon is a plug.
To control it you would need to do one of the following options:
  1. capture the ID of the remote that controls it and create a switch in HA
  2. generate a new switch in HA and pair it with the plug
You can get the remote ID from the logs. Pressing the remote buttons, will show the logs in HA.
For timestamp that was good thanks :smiley:
For data from oregon, i don’t understand ,
i can see them in entities now. But no data.
Can it be a auto add problem ?
I can’t see data from oregon in debug log …
Yeah the chacon is a plug. I can’t see nothing from him in log for the moment… (using the button on him )
Edit:
When i push out, and push in another battery pack in oregon. The id change, ( it’s for try to have new data incoming in rflink )…
Edit:
I wrote the id like this :
  - platform: rflink
    automatic_add: false
    devices:
      oregontemphygro_22806_temp:
      oregontemphygro_22806_hum:
      oregontemphygro_22806_hstatus:
      oregontemphygro_22806_bat:
      oregontemphygro_22806_update_time:
And have no data incoming. If i delete automatic_add . I can see them in home-assistant.log when i take out the battery, and push them inside another time. But the id change.
And no data in Card :frowning:
Why is it so hard XD
That is because RFLink, sometimes populate the data from one device (the oregontemphygro_22866 in your case) as if they were several devices (2, 3 or even 4 different devices).
It is not an HA problem, it is how RFLink works.
To solve it, the ‘others’ devices can be configured as aliases of the known device. This way, the data from ‘all’ devices will be grouped into the main device.
It is best to do the test. In the traces you will see how the data from the ‘alias’ device is added to your oregon device.
I’m going to look in the doc about this.
id of oregon changing when i change battery is normal ?
Yes, it is pretty normal to any RF sensor to change the ID when you replace batteries.
How ok, i’m bad sorry.
So why i can’t add it properly ?
automatic_add: true let me see the oregon in logs
then i use the id found and i put them in configuration.yaml
Then i have no data coming on cards.
And it dissapear from logs …
If i do :
i can see nothing from oregon…
I don’t know why but now it’s working.
i haven’t change anything .
for the Chacon i have found this. But i don’t know where is
https://media.discordapp.net/attachments/706968301334560829/737430082641068032/Template.png?width=508&height=662
But they said to launch a command in Developpement tools, template. But i can’t find it :frowning:
Thanks again for help @javicalle
Sorry, but I’m not sure if I’m understanding you.
I think that your sensor already works for you, is it?
In any case, in the logs (at debug level) you should be able to see the signals that arrive to you, regardless of how you have configured the automatic_add property.
The image that you attach is for the rfxtrx. It’s similar to RFLink but don’t work the same way.
The ‘Developer tools’ tab it’s on the left panel (with a hammer icon). I think it doesn’t show unless you are an admin user.
You should be able to access it through the URL:
http://<your_ip>:<your_port>/developer-tools
I’m sorry about that, i’m french and pretty bad in English.
The sensors looks like to works, only oregon looks like to work sometime yes, sometimes no :frowning:
oregon
In logs at debug level, i can’t see my chacon dio using the plug button.
I have to found how to do, or i’ll give it back to amazon :frowning:
I have success added sensor form my alarm system, and trying to understand how to have
the rf signal between panel_button and the air-raid siren
Too many topics at once.
Let’s go one by one.
The sensors should leave traces on the logs. That information will tell you which ID is exposing RFLink for your devices.
You can check all your devices status at “states” tab in “Developer tools” view:
  • https://<your_ip>:<your_port>/developer-tools/state
    Here you must see your device status (temp, hum, etc)
Once you can see here your devices, can be added at your frontend.
