My configuration.yaml file is growing and I’d like to do some clean up. I’ve started with splitting it out into multiple files, but there’s still a lot of duplication. I use mostly shelly devices and they need to have various settings defined which are repeated between them. Is there a way to configure an MQTT template and then re-use that?
For example, I’d like to remove the duplication in these entries:
- platform: mqtt
schema: template
command_topic: "shellies/shellyrgbw2-tvtop/color/0/set"
state_topic: "shellies/shellyrgbw2-tvtop/color/0/status"
effect_list:
- 0
- 1
- 2
command_on_template: >
{"turn": "on"
{%- if brightness is defined -%}
, "gain": {{brightness | float | multiply(0.3922) | round(0)}}
{%- endif -%}
{%- if red is defined and green is defined and blue is defined -%}
, "red": {{ red }}, "green": {{ green }}, "blue": {{ blue }}
{%- endif -%}
{%- if white_value is defined -%}
, "white": {{ white_value }}
{%- endif -%}
{%- if effect is defined -%}
, "effect": {{ effect }}
{%- endif -%}
command_off_template: '{"turn":"off"}'
state_template: "{% if value_json.ison %}on{% else %}off{% endif %}"
brightness_template: "{{ value_json.gain | float | multiply(2.55) | round(0) }}"
red_template: '{{ value_json.red }}'
green_template: '{{ value_json.green }}'
blue_template: '{{ value_json.blue }}'
white_value_template: '{{ value_json.white }}'
effect_template: '{{ value_json.effect }}'
qos: 2
- platform: mqtt
schema: template
command_topic: "shellies/shellyrgbw2-tvbottom/color/0/set"
state_topic: "shellies/shellyrgbw2-tvbottom/color/0/status"
effect_list:
- 0
- 1
- 2
{"turn": "on"
{%- endif -%}
{%- endif -%}
{%- endif -%}
{%- endif -%}
qos: 2
Ideally, I would like to do something like this:
- platform: configTemplate
schema: template
command_topic: "shellies/shellyrgbw2-<namevariable>/color/0/set"
state_topic: "shellies/shellyrgbw2-<namevariable>/color/0/status"
effect_list:
- 0
- 1
- 2
{"turn": "on"
{%- endif -%}
{%- endif -%}
{%- endif -%}
{%- endif -%}
qos: 2
And then configure both entities like this:
- platform: configTemplateImplementation
template: MqttRgbw
var_name: tvtop
template: MqttRgbw
var_name: tvtbottom
