Configuration validation does not work with Raspberry Pi All-In-One Installation
pi@RPI-Hass:~ $ hass --script check_config
-bash: hass: command not found
hey @cvanandel,
that’s because that installation is using virtual envs. You need to change to the Virtual Env before execute ir. Something like this:
Change to hass user:
sudo su -s /bin/bash hass
Change to virtual enviroment
source /srv/hass/hass_venv/bin/activate
once there you can execute hass:
give it a try …
@davedan
Thanks for the reply davedan, I will give it a try I am still a noob at this
@davedan
That worked like a charm, thanks a bunch
Hi davedan
I’m having the same problem and your instructions to cvanandel don’t work either…
pi@hassbian:~ $ hass --script check_config
Config does not exist: /home/pi/.homeassistant/configuration.yaml
pi@hassbian:~ $ sudo su -s /bin/bash hass
No passwd entry for user ‘hass’
pi@hassbian:~ $ source /srv/hass/hass_venv/bin/activate
-bash: /srv/hass/hass_venv/bin/activate: No such file or directory
You can use
hass --script check_config -c /path_to_configuration.yaml
replace /path_to_configuration.yaml to wherever your homeassistemt configuration is.
my configuration file is under
network/HASSBIAN/homeassistant/configuration
how would I type that into putty?
A normal hasbian install would create the configuration files in /home/homeassistant/.homeassistant so the command would be
hass --script check_config -c /home/homeassistant/.homeassistant
Note the DOT in front of the second homeassistant. In Linux creating a folder with a leading dot makes that folder hidden.
