The issue is closed with the reason that it is happening if you have custom_components. I had indeed hacs and breaking changes and after removing them it is super quick. Sadly, hacs is extremely useful and temporarily deactivating it breaks all custom cards
i have HACS and breaking changes installed as well as 1/2 dozen other custom integrations and my config check time is around 15-20 seconds. I don’t really use the config check much so not sure if that’s excessive
maybe it’s a resource problem. i’m on a rpi running docker hassio. i can’t really recall when it started since i wasn’t home the last weeks. but it wasn’t like that a few releases ago. funny enough i just tested activating breaking_changes since it’s basically doing nothing more than a simple poll, but with the same excessive amount of time as with hacs (that does a lot of data reloading).
