Configuration wizard loading indefinitely
Hi
With some integrations the configuration wizard loads forever until you reload the page or get a timeout error.
Same problem with some HACS integrations. e.g. the HACS integration “Watchman” takes forever to load until you interrupt the process. After a reload the integration seems to be installed.
But then it takes forever again when adding the integration under “Devices & Services” and you don’t get any result.
I have this problem with some HACS integrations, but also with normal integrations like Google Calendar.
Most other integrations can be added normally.
Can anyone help me with this? Thanks a lot!image
What happens when you hit F5?
The page simply reloads.
In HACS it is shown as installed.
In “Devices & Services” it’s like i have never tried to add one of these integrations
