Configuration.yalm and !include
Hi folks,
my question is…
Is it possible to use more than one !include inclusion of sensors or similar and having a sensor:section in the configuration.yaml
Example:
sensor: !include mqtt_sensors.yaml
sensor: !include garden_sensors.yaml
  - platform: history_stats
    entity_id: switch.solarpump
    state: "on"
    type: time
    start: "{{ today_at('00:00') }}"
    end: "{{ now() }}"
Yes, but you can’t repeat sensor: like that
sensor garden: !include garden_sensors.yaml
sensor other_word_here:
    state: "on"
    type: time
    end: "{{ now() }}"
will work
Try this:
sensor mqtt: !include mqtt_sensors.yaml
    state: "on"
    type: time
    end: "{{ now() }}"
There is a similar example (but using lights) in the documents:
What about the mqtt: tag.
mqtt:
  binary_sensor:
…and the HA function to reload manually configured mqtt entities?
Are there any limitations to be expected?
I’d look a using packages instead. They merge together very nicely.
Create a packages subfolder, then put this into configuration.yaml
homeassistant:
  customize: !include customize.yaml
  packages: !include_dir_named packages
Same applies there, you can’t repeat mqtt: or sensor: (etc)
…and what do I have to put into this subfolder?
