I’ve been getting an odd error lately when trying to make any changes in configuration.yaml
File ‘configuration.yaml’ could not be parsed, it was referenced from path ‘configuration.yaml’.This file will be ignored. Error(s): - YAMLSemanticError: Implicit map keys need to be followed by map values
I migrated from and SD card to an SSD about 2 weeks ago. I’m not sure if this has to do with that as I did not test after the migration.
The Pastebin is below. The config.yaml file is pretty simple. I have not done much with it a few weeks prior to the SSD migration. Also, the Check Configuration gives me a green Configuration valid! message when I run the test.
I removed the extra spaces that rossk suggested. I had those in the since the beginning and this is the first time this has given me issues. I no longer get the error message like above. I will play around with it the next couple of days and see if this fixes the issue.
