Hello, I have installed Hassi.o on a Raspberry Pi 4 model B 32 bits. Raspberry Pi has boot up, Home Assistant is yet available, when I edit configuration.yaml I notice that this file is only has 15 lines. I do not know what is thle problem.
I need an standard configuration.yaml file. Where can I get it?
That probably is the std config file for new installs
But you’re looking at it.
What makes you think it’s “defective”?
This my configurati9n.yaml
Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
Uncomment this if you are using SSL/TLS, running in Docker container, etc.
http:
base_url: example.duckdns.org:8123
Text to speech
tts:
- platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
2 things.
- Use proper formatting for the forums.
- There is nothing wrong with that configuration yaml. It is the default configuration. Why do you think it is broken?
