You need to use the binary sensor for what you want to do.
# Turn on kitchen light
- alias: Turn on kitchen light when there is movement
platform: state
entity_id: binary_sensor.aeotec_zw100_multisensor_6_sensor
to: 'on'
service: homeassistant.turn_on
entity_id: switch.telldus_tzwp100_plugin_switch_switch_4
- alias: Turn off kitchen light 10 minutes after last movement
platform: state
to: 'off'
for:
minutes: 10
service: homeassistant.turn_off
I came across this error when I referenced a file that did not exist.
Copied my old config to a new setup and it referenced a separate config file that I had not brought over. In my case it was customize, my config referenced including customize.yaml but I had not yet brought over customize.yaml. So the error when checking configuration was configuration.yaml not found, but it was actually saying a file referenced in configuration.yaml, in this case customize.yaml, was missing. So I #’d the referenced file and the error went away.
