Configuration yaml file location on HA docker container Qnap server
I installed HA core on container Qnap NAS. All in default when I run installation. Now need to access configuration.yaml manually.
Looked around and still stuck. suppose on /config folder. However, I can’t find the folder. Qnap NAS auto created share. However, no way to find the right folder.
You should map your /config to a known folder on your NAS. I do it like this on my QNAP:
volumes:
      - /share/container/service:/config
and I have a shared folder named container:
try to find where is config folder on Qnap server
You create the folder and map to it. In my example over the folder is /share/container/service and the /config in the container stores its config there.
thanks found it to overlay folder
