I’m tring to access to file configuration.yaml HA thorught portainer console. I tried to install the editor with:
sudo apt install nano
The answer that I had back was sudo apt install nano command not found
do you know why?thanks
Hi Geme84,
If you are running HAOS or Supervised, Portainer is not supported. It causes issues and conflicts with other functions.
Also many of the things you pull in thru apt in a Linux install are not there in the HAOS so you will not find them that way.
