I have these two entries in my /config/configuration.yaml No matter how I put them I can only get one to work. I can’t figure out what to add or the order to make both parts work. Any guidance? I’ve been fighting this one for a while now. I can’t find any reference to help solve it.
sensor: !include sensor.yaml
- platform: history_stats
name: Well Pump ON today
entity_id: binary_sensor.well_pump
state: "on"
type: time
start: "{{ now().replace(hour=0, minute=0, second=0, microsecond=0) }}"
end: "{{ now() }}"
IIRC, the include should be a child of the homeassistant
key.
homeassistant:
state: "on"
type: time
end: "{{ now() }}"
Thanks for the suggestion. When I put the include as a child, I get a configuration error.
Configuration invalid!
extra keys not allowed @ data[‘sensor’]
What is your thought about that?
Sorry about that… it’s been a while since I switched to Packages (which I highly recommend if you’re planning on using multiple directories to organized you config.
You can use a split:
sensor split: !include sensor.yaml
state: "on"
type: time
end: "{{ now() }}"
Just make sure that your history stats sensor and all other sensors in the configuration.yaml
file are nest under a single top-level sensor
key.
Thanks for the help! I used the split method just because it was easy.
