For me, there is too much ‘bloat’ using default_config, so I want to get rid of it.
I can’t find anywhere what the minimum configuration.yaml file would look like.
So I can just build up my stuff from scratch, no automatic stuff unless I want it…
If I just delete default_config, the system of course won’t come up.
Any suggestions?
Not really sure what would categorize as “bloat” in the default_config…
The danger of not having it enabled, is to miss new features, then having to come back to the forum with a cryptic “It doesn’t work”. Recent example: The Energy panel is not enabled by default unless you use default_config. It happened to me, so I actually added it
I would categorize as bloat items that I don’t use but which adds, e.g., entities that I don’t need.
I don’t think any of those adds anything, but potential capabilities.
Energy might categorize as bloat, though, as it adds some undesirable UI if you don’t use energy.
Yeah, did it too. Then I wondered where is that supposed to come from by for others, then I found out about default_config (I have a grand-fathered config )
P.S.: My point is: sure, the more control, the better, and if you know what you’re doing, fair enough. But the OP is a newcomer. Not sure he does know what is important and what is not. Strange. The forum says he’s a newcomer, but also that he is in since 2018
Ah no, first post in 3 years he’s a member
Thanks everyone for your replies. I didn’t mean to use ‘bloat’ as a derogatory term in this case.
There are many things that I don’t want to use that are automatically put in. True, I’m now an ‘old pro’ at this, but I do have a little programming experience… anyway, thanks again. I will go through the default_config list an pick what I do and don’t want, and take it from there.
again, thanks all … g
