More and more I get familiar with Home Assistant. I hope you can give me more clarity about the following.
Often I see to add [code] to configuration.yaml. I didn’t want to make that file too large, so I started to seperate configs into files per device.
I added 2 Broadlink devices, learned the IR codes and configured them.
In configuration.yaml I put
switch: !include _ir_beamer_office.yaml
switch: !include _ir_beamer_guest.yaml
The outcome was that only ‘guest’ was working, not office.
If I merge the into one, both devices work.
FILE: _ir_beamer_office.yaml:
- platform: broadlink
mac: C8:F7:42:74:FC:34
switches:
- name: Office - AIRCO
command_on: ‘[learned code]’
command_off: ‘[learned code]’
FILE: _ir_beamer_guest.yaml:
mac: C8:F7:42:63:19:9A
switches:
- name: Guest - AIRCO
Why don’t the two seperate files not work, and if I merge them into one they do?
Thank you for your input.
