I’m fairly new (10 days) to HA so please excuse any newbie-ness.
After upgrading my Docker container (Ubuntu Server 16.04) on a fully patched machine from 0.63.3 to 0.64.1, the Docker instance of HA doesn’t seem to be pulling in my configuration files located in /home/homeassist.
Is there a way for me to tell 1) where the Docker image is looking for the configuration files, 2) look at what volumes are being attached to the Docker image?
Here is the command I used after removing the old docker container: sudo docker run -d --name=“home-assistant” -v /home/homeassist -v /etc/localtime:/etc/localtime:ro --net=host homeassistant/home-assistant
configuration.yaml is located in /home/homeassist
The HA instance is running, it just appears to be a fresh install (not pulling in my previous config files)
Adding :/config after the “-v {config directory}” was exactly the “DUH” piece I was missing.
I used the new command:
sudo docker run -d --name=“home-assistant” -v /home/homeassist:/config -v /etc/localtime:/etc/localtime:ro --net=host homeassistant/home-assistant
