The only thing I can think of would be airconditioning (climate). I wondering if a Cool Peak Scene could save money.
There is the set temperature and swing. I am wondering if prior to peak you drop the swing to 1, maybe drop the temp a degree, then at peak set the swing to 10 and raise the temp 3. That means it has to drop 7 below desired temp if and when it does run, it will only run a little. Maybe there a better way to coast through peak. The values are just examples, I not sure what realistic ones would be. Our electric company Peak is June-Aug 3pm till 7pm. So the trigger would include testing what month and home/away besides time of day.
Here is a sensor I rigged up that works with the Time-Of-Use rates in Ontario:
