I tried the upgrade to Configurator 3.1 (Hassio v0.91.2) and it seems to have failed. See attached screen shot - "hassio.local refud=sed to connect).
Not much else in terms of info given?
Worked perfectly on Configurator 2.
How are you trying to connect?
There were major changes in 3.X that are not well documented but we have found answers…
Locally through the menu item (wrench).
Web UI connection works fine.
OK, that entry has changed significantly. Here is what works for me, replacing the old iframe
panel_custom:
- name: hassio-main
sidebar_title: Configurator
sidebar_icon: mdi:wrench
js_url: /api/hassio/app/entrypoint.js
url_path: configurator
embed_iframe: true
require_admin: true
config:
ingress: "core_configurator"
Do not ask me to explain it, though.
Excellent!
Worked straight off the bat.
Much appreciated.
