Configurator doesnt load
Im running hassio on a RPi3.
I was trying to run a custom integration adding the Ring Alarm via mqtt as seen in another post. So I have been trying to load that up on a second RPi 3.
I noticed that now I am no longer able to access the front-end configurator by hitting the icon. I am able to access the configuration.yaml file via the samba add on, and if I go to the configurator plug in component, and hit open in a new window, I am able to do so. But it is a little inconvenient not having the front end icon work. I haven’t changed any ports. I didn’t change my configuration.yaml file for anything important. When I hit the configurator icon, the screen is grey and there’s a frowny-face file when I hover over the space that says “the connection was reset”.
I tried wiping and restoring my previous back up, but the problem persists.
Any thoughts?
