Configurator not running from sidebar
Id like some help knowing whats up with my Configurator not loading from the sidebar:
only from the Hass.io menu’s Open Web UI:
I recently had to change things from hassio.local to the rpi’s ip address. The only thing I havent changed is this instance here in my configuration.yaml:
panel_iframe:
  configurator:
    title: Configurator
    icon: mdi:wrench
    url: http://hassio.local:3218
system_health:
because Im not sure if ill mess up my ui and have a hard time getting it back. It does seem like it might be related. Can anyone confirm?
Tks
Configurator supports Ingress now, so you can remove the iframe from configuration.yaml and switch on the “Show in sidebar” option found in your second image. I can confirm that this works as expected.
tks, it worked
