I am unable for some reason to reset the app.
I have the Configurator configured as an iFrame
When I try and access it from the hamburger menu I get the error:
no auth header received
I tried resetting chrome, resetting the app but no matter what I do I don’t get prompted for authentication at all it just gives the above error.
I also deleted the app and re-installed it - no change.
I once cancelled when configurator asked for username and password and no I it just comes up with an error when I try and access the configurator in the app.
Same here and didn’t find any solution so far.
pplante
(philippe plantegenest)
October 15, 2018, 12:50pm
4
Hello
I have the same problem Here.
I’ve set up SSL access, so i can access to Home Assistant and the Configurator panel from any PC with chrome.
On my ipad i can access to Configurator in safari or chrome also by using https://xxxxx.duckdns.com:3218 and it show me the auth box with user name and password so i can access with no problems.
But inside the Home Assistant App access to the Configurator shows no auth box and this message only “no auth header received”.
For info Node-RED configured like Configurator shows the dialog boc in ipad app and i can access to this panel.
so please what are we doing wrong with Configurator so we can’t access it from the ios app ?
The old iOS app does not work properly with configurator. The new app (currently beta) does work. Switch to the beta app…see here 1.5.0 Feedback
pplante
October 15, 2018, 9:58pm
6
Thanks you working fine now .
Have a good evening
I cannot access configurator from within the app but from Safari when on my network using https.
I can access configurator from my mac both using the panel-iframe and by opening a new tap and entering my duckdns adress when on my network.
I cannot access configurator remotely.
My setup of the configurator Addon is:
"username": "redacted",
"password": "redacted",
"ssl": true,
"certfile": "fullchain.pem",
"keyfile": "privkey.pem",
"allowed_networks": [
"192.168.0.0/16",
"172.30.0.0/16",
"0.0.0.0/16"
"banned_ips": [
"8.8.8.8"
"banlimit": 0,
"ignore_pattern": [
"__pycache__"
"dirsfirst": false,
"enforce_basepath": false,
"notify_service": "persistent_notification.create"
The 3218 port i open.
Can you help me?
Which version of the app? BTW, 0.0.0.0/8 is correct not 0.0.0.0/16
The version is 1.5.0 (21)
I changed to 0.0.0.0/8. No difference.
Tried to connect remotely from iPad within Safari with the result “Policy not fulfilled”. I see in the log that I get:
WARNING:2018-10-18 11:07:33,170:main :Client IP banned.
INFO:2018-10-18 11:07:33,171:main :79.102.138.161 - “GET / HTTP/1.1” 420 -
Trying to connect from within the app juste renders a blank page.
Went back to the log after having tried also from my iPhone with the following additional:
INFO:2018-10-18 11:11:40,309:main :94.234.36.9 - “GET / HTTP/1.1” 401 -
WARNING:2018-10-18 11:12:00,920:main :Client IP not within allowed networks.
INFO:2018-10-18 11:12:00,921:main :94.234.36.9 - “GET / HTTP/1.1” 420 -
INFO:2018-10-18 11:12:01,905:main :Requesting authorization
INFO:2018-10-18 11:12:01,906:main :94.234.36.9 - “GET /apple-touch-icon-120x120-precomposed.png HTTP/1.1” 401 -
INFO:2018-10-18 11:12:02,643:main :Requesting authorization
INFO:2018-10-18 11:12:02,644:main :94.234.36.9 - “GET /favicon.ico HTTP/1.1” 401 -
INFO:2018-10-18 11:12:03,319:main :Requesting authorization
INFO:2018-10-18 11:12:03,321:main :94.234.36.9 - “GET /apple-touch-icon-120x120-precomposed.png HTTP/1.1” 401 -
INFO:2018-10-18 11:12:03,998:main :Requesting authorization
INFO:2018-10-18 11:12:04,000:main :94.234.36.9 - “GET /favicon.ico HTTP/1.1” 401 -
INFO:2018-10-18 11:12:04,702:main :Requesting authorization
INFO:2018-10-18 11:12:04,703:main :94.234.36.9 - “GET /apple-touch-icon-120x120.png HTTP/1.1” 401 -
INFO:2018-10-18 11:12:05,579:main :Requesting authorization
INFO:2018-10-18 11:12:05,581:main :94.234.36.9 - “GET /apple-touch-icon-120x120.png HTTP/1.1” 401 -
INFO:2018-10-18 11:12:06,444:main :Requesting authorization
INFO:2018-10-18 11:12:06,445:main :94.234.36.9 - “GET /apple-touch-icon-precomposed.png HTTP/1.1” 401 -
INFO:2018-10-18 11:12:07,298:main :Requesting authorization
INFO:2018-10-18 11:12:07,299:main :94.234.36.9 - “GET /apple-touch-icon-precomposed.png HTTP/1.1” 401 -
INFO:2018-10-18 11:12:08,179:main :Requesting authorization
INFO:2018-10-18 11:12:08,180:main :94.234.36.9 - “GET /apple-touch-icon.png HTTP/1.1” 401 -
INFO:2018-10-18 11:12:09,043:main :Requesting authorization
INFO:2018-10-18 11:12:09,044:main :94.234.36.9 - “GET /apple-touch-icon.png HTTP/1.1” 401 -
