I’m trying to get the Observe Events to feature in HASS configurator to work. I’ve added my websocket URI as wss://mydomain.tld/api/websocket and generated a Long Lived Acces Token which I’ve added in the API password.
I keep getting the following error every time I try to connect.
Are you using the hassio addon? That hasn’t been updated in a while. Only the most recent configurator (0.3.4) supports long lived access tokens. A workaround would be to enable the legacy api_password and use that instead.
That’s probably why. HASS Configurator that I’m running reports as 0.3.2. Is there no version available as a HASSOS add-on that has the latest version [0.3.4]?
The Pull Request for the official add-on is open since November of last year and still not has been merged.
But you can uninstall it and switch to my repository and install the latest version from there: https://github.com/danielperna84/hassio-addons
